Greetings,
I finally got TTS working. However, Everytime there is a space my media_player, Google home, says “percent twenty”.
Anybody know how to fix this?
Greetings,
same for me with the last release 0.113.2
Yep, just started doing that with 0.113.2 - All my announcements are a mess
Following.
I put a dash between the words as a temporary fix.
“Welcome-home”
It has been fixed in 0.113.3.
Seems it’s back in 0.114.4 but only with the latest Supervisor I feel? Been rocking 0.114.4 for >2 weeks but in the last 48hrs, the 20 percent is back and the only change is the recent frequent supervisor updates now on 242.
EDIT 23rd Sept 20: I found my problem which crept in somewhere recent that seems to be related to the entity_id
: change. The code below reads out the text with the 20 percent error and it’s the only TTS announcement that does and I have lots.
- alias: 'Notify front door battery low'
initial_state: true
platform: numeric_state
entity_id: zwave.frontdoor_deadbolt
value_template: '{{ state_attr("zwave.frontdoor_deadbolt", "battery_level") | int(100) }}'
below: 80
condition:
condition: and
conditions:
- condition: state
entity_id: alarm_control_panel.home_alarm
state: 'disarmed'
- condition: time
after: '08:00:00'
before: '21:00:00'
- service: notify.hass_synochat
message: "Deatbolt battery is below 80%"
- service: script.ghm_tts ## Calls the Google Home app group called media_player.tts_homes
data_template:
tts: "Bummer. The batteries in the door lock went below 80 percent"
volume: 0.5
I changed the value template to "{{ state.attributes.battery }}"
and the problem disappeared but I suppose I could have removed the entity_id:
field instead?
I’m on 0.114.4, but only the Home Assistant Core in a Docker container, which works fine. Just wanted to mention that.
