braaak
1
Hello out there,
I am a pretty newby and amateur using HA, so thank you all for your patience and goodwill!
I activated picoTTS via my configuration.yaml
tts:
- platform: picotts
language: 'de-DE'
service_name: picotts_say
This is all that has to be done as it should be already integrated into HA out of the box - right?
But as I tried to use
- service: tts.picotts_say
message: Das ist ein Test
entity_id: media_player.treppenhaus_lautsprecher
I do not hear any speech…
Below you’ll find trace and debug screenshots.
Where am I wrong?
Any help is really appreciated!
Braak
![Ohne Titel 1](https://community-assets.home-assistant.io/original/4X/8/d/c/8dc17afce9f58921b051cd5cd68b3fa169861761.png)
![Ohne Titel 2](https://community-assets.home-assistant.io/original/4X/5/8/b/58ba21c892a82910b733a292d62c090796498ee0.png)
pedolsky
(Pedolsky)
2
Have you media_source:
enabled in your configuration.yaml
Also my Pico service call has no line target:
braaak
3
Changed target, still not working working.
![:frowning: :frowning:](https://community.home-assistant.io/images/emoji/twitter/frowning.png?v=10)
What do you exactly mean by
media_source:
Can you please give an example? I thought media sources are not necessary just for TTS use, do they?
pedolsky
(Pedolsky)
4
If I remove media_source
from my configuration.yaml
I get the following error:
websocket_api script: Error executing script. Error for call_service at pos 1: Media Source not loaded
Vandana
(Vandana Dass)
5
How to set speed of picotts ?
Kindly guide
