TTS Slow - KODI
Ok here’s the setup - RPi 3 running HASS AIO - RPi2 running KOdi connected to Denon networked receiver.
I can get TTS to say stuff via KODI if I use the dashboard to send TTS via KODI media player - but I get like the last 2 seconds of the tts not the whole sentence.
Also if I try to send TTS direct to Denon receiver (which HASS sees as media player) I never hear a thing.
Any ideas?
Noted log shows this as well when KOdi plays the tts - not the Denon -
17-01-13 17:27:43 homeassistant.components.tts: Error on load tts: Wrong tts file format!
17-01-13 17:28:09 homeassistant.components.tts: Error on load tts: Wrong tts file format!
What TTS platform are you using?
sorry - I missed this reply - google tts
Just checking - did anyone have any input on this?
No, sorry - I don’t use Kodi. I asked what platform because I know that the VoiceRSS platform lets you specify formats; Google only uses MP3.
This could be an option if you can figure out what format Kodi is expecting.
@rpitera - thanks for the response! I can’t figure out why my Denon doens’t show an error, KODI does - but KODI plays and the Denon doesn’t. May have to play around some more…
Vy the way - I tried VoiceRSS ove rthe weekend - same issue, in fact almost worse. And I’ve noted my Denon networked receiver does not like to receive any TTS - so Kodi is my test bed - but it’s really slow and cuts off. Just passing feedback back to the forum.
Odd. It may be worth your time to put in an issue on Github.
@rpitera -
Turned in - issue #5523 - :wink:
HOW IT WIRKS? any erro?
I’m not sure what you’re asking - as to how the TTS in Kodi works, I will defer to the developers. I did not get any errors. I think I’ve seen other people with similar issues (KODI + TTS) - at this time I just use a Google Home and it works fine.
