TTS stops working after some time
I’ve been excited to start using the Home Assistant Voice devices that arrived yesterday. Having set it up it’s great however after leaving it alone for 15 minutes or so it stops responding with TTS voice. Commands are still recognised and actioned but no speech.
The assist debug page shows the TTS is completing and has the raw sound that plays just fine so it seems to be a device/connection to device issue.
Sending a TTS action to it also fails to produce any sound but it will play media. Anybody have any idea what’s going wrong here?
TIA
I’m having very similar issues. Have you checked the debug page in the voice pipeline to see if it thinks it said something to you?
I have had it open while trying to talk to it. It’s not real time, but if I refresh I can see what I asked it and what it “responded” with even though I didn’t hear anything. Occasionally it will come back to me very late with a response. If it actually responds or not, I can play the recording of what it thinks it said.
I say that my issues are similar only because I make follow up requests to it and it does start to work. (I’m just repeatedly asking for the time)
I started seeing the same thing yesterday. My Wyoming satellites are working fine, but the two Voice PE devices are intermittent (failing to do TTS most of the time, but not always). Looking at the debug page for the assistant, the correct response is there (and I can play it from the debug page), but I don’t hear it on the Voice device.
I’ve been having the same issue. I can see and play the response in the debug log, but the response didn’t actually play on my android app. It will play sometimes, but not most of the time.
Same here, 1 out of my 3 Home Assistant Voice PE has pretty consistent issues with normal timing for the action to take place (ie - lights on/off), but an incredibly long delay for it to verbally respond. Looking at the debug menu, the TTS has already been calculated and it thinks the entire interaction is done, but the Voice PE hangs for up to a minute afterwards before actually responding verbally.
Is there any solution for this? It seems I have also the same issue on 2025.4.1
Same issue for me. Sometimes PE does not output the speech and it also just stops speaking in the middle of the sentence, even though debug log shows that the TTS file was complete.
Is there anything new on this?
I have exactly the same problem.
I am understood correctly (also verified via debug log), the action is executed correctly and according to debug the TTS is also generated correctly afterwards (I also verified that by listening to it on the PC via debug), but in 9 out of 10 cases I have no output on the Voice PE.
Also the assist_satellite.announce produces no output most of the time - although the ring on the Voice PE lights up briefly.
