Thanks that work very well
message: oven is on for {{ (as_timestamp(now()) - as_timestamp(states.automation.oven_warning.attributes.last_triggered))| round(0) //60}} minutes!
hi @pnbruckner seems the new Sonos setup have broken the time syntax
Any idea on how to tell HA that its a syntax and not having it spelling it outâŚ
Youâre going to have to fill in some details as to what used to work and whatâs different now. I donât use sonos or TTS, so I have no idea what might have changed.
sorry before I used your excellent syntax
message: "Victoria og Thomas Nu er det sengetid klokken er {{ now().strftime('%H %M') }}"
But now it doesnt recognize the syntax it just speaks the code?
so maybe its just the {{ that have somehow changed?
Please post the entire automation and/or script as it/they exist now.
Yes of course sorryâŚ
script:
# Sonos https://www.home-assistant.io/cookbook/sonos_say/
sonos_say:
alias: "Sonos TTS script"
sequence:
- service: sonos.snapshot
data_template:
entity_id: "{{ sonos_entity }}"
- service: sonos.unjoin
data_template:
- service: media_player.volume_set
data_template:
volume_level: "{{ volume }}"
- service: tts.google_say
data_template:
message: "{{ message }}"
- delay: "{{ delay }}"
- service: sonos.restore
data_template:
- service: script.sonos_say
sonos_entity: media_player.sonos_koekken
volume: 0.5
delay: '00:00:05'
In your automation action you need to use data_template
instead of data
Like you had before:
- service: script.turn_on
entity_id: script.say
data_template: <============
variables:
where: 'kkken'
what: 'Klokken er nu {{ now().hour}} {{ "%0.02d" | format(now().strftime("%-M") | int) }}'
Thanks allot @pnbruckner I have been trying so many things, that i completely missed that (Had to change all my scripts to the new Sonos syntax, another breaking change)
@pnbruckner one last question - of topic, I am trying to update my old Sonos TTS script to the new above, and I know you donât have Sonos but maybe you can see something I canât
First just a normal text input variable no change:
# Announcement on Sonos
input_text:
announce_sonos:
initial: Some Text
then the new script:
# Announce TTS input over Sonos
- alias: Announce TTS Input Over Sonos
hide_entity: true
- platform: state
entity_id: input_text.announce_sonos
entity_id: script.sonos_say
data_template:
volume: 0.5
message: "{{ states.input_text.announce_sonos.state }}"
delay: '00:00:05'
The old one:
## Announce TTS input over Sonos - alias: Announce TTS Input Over Sonos hide_entity: true trigger: - platform: state entity_id: input_text.announce_sonos action: - service: script.turn_on entity_id: script.say data_template: variables: ## Remember to check that the sonos media_player name is correct below! where: 'sonos_koekken' what: "{{ states.input_text.announce_sonos.state }}"
And the old Sonos script now obsolete and a little long (Replaced with the above in my former post):
# > SONOS TTS script to speak with text-to-speech
say:
alias: SONOS TTS
sequence:
data_template:
entity_id: "{{ 'sonos.' ~ where }}"
with_group: yes
data_template:
data_template:
volume_level: 0.45
data_template:
message: "{{ what }}"
language: 'da'
# Add a delay (default 1) in a length which you think fits best for all the things you want to say over TTS
- delay:
seconds: 1
- delay: >-
{% set duration = states.media_player[where].attributes.media_duration %}
{% if duration > 0 %}
{% set duration = duration - 1 %}
{% endif %}
{% set seconds = duration % 60 %}
{% set minutes = (duration / 60)|int % 60 %}
{% set hours = (duration / 3600)|int %}
{{ [hours, minutes, seconds]|join(':') }}
- service: media_player.sonos_restore
data_template:
entity_id: "{{ 'media_player.' ~ where }}"
with_group: yes
You need to be careful how you invoke a script. There are two ways, and each way passes variables differently. You should change this:
data_template:
volume: 0.5
delay: '00:00:05'
to this:
data_template:
volume: 0.5
delay: '00:00:05'
See this for more details.
Thanks I will look into this, doesnât seem to be a quick fix LOL
I have this:
data_template:
message: 'The time is {{now().strftime(''%H'')}} o clock.'
entity_id: media_player.google_home_mini
service: tts.google_translate_say
And my problem is in the morning get this: âThe time is 08 o clock.â
How can do this without 0?
Try this Itâs 12 Hour and does not need the oâclock as google does that part quite well.
- service: tts.google_translate_say
entity_id:
- media_player.google_kitchen
data_template:
message: "Its {{ now().strftime('%-I:%M') }}."
I do this.
(Iâm not posting this because I think it is clever. On the contrary, there has to be a better way to achieve what Iâm doing here in a lot less lines )
{% set message = '' %}
{# DATE AND TIME #}
{% set hrs = (now().hour) %}
{% if hrs > 12 %}
{% set hrs = hrs - 12 %}
{% endif %}
{% set hrs_s = hrs | string %}
{% set min = (now().minute) %}
{% set min_s = min | string %}
{% set day = now().strftime(" on %A the ") %}
{% if min == 0 %}
{% set message = message + hrs_s + " o'clock" + day %}
{% elif min in (5, 10, 20, 25) %}
{% set message = message + min_s + ' past ' + hrs_s + day %}
{% elif min in (35, 40, 50, 55) %}
{% set message = message + (60 - min) | string + ' to ' + (hrs + 1) | string + day %}
{% elif min == 15 %}
{% set message = message + 'quarter past ' + hrs_s + day%}
{% elif min == 30 %}
{% set message = message + 'half past ' + hrs_s + day %}
{% elif min == 45 %}
{% set message = message + 'quarter to ' + (hrs + 1) | string + day %}
{% elif min == 1 %}
{% set message = message + min_s + ' minute past ' + hrs_s + day %}
{% elif min == 59 %}
{% set message = message + (60 - min) | string + ' minute to ' + (hrs_s + 1) | string + day %}
{% elif min < 30 %}
{% set message = message + min_s + ' minutes past ' + hrs_s + day %}
{% elif min > 30 %}
{% set message = message + (60 - min) | string + ' minutes to ' + (hrs + 1) | string + day %}
{% endif %}
{% set message = message + now().day | string %}
{% if now().day in (1, 21, 31) %}
{% set message = message + 'st ' %}
{% elif now().day in (2, 22) %}
{% set message = message + 'nd ' %}
{% elif now().day in (3, 23) %}
{% set message = message + 'rd ' %}
{% else %}
{% set message = message + 'th ' %}
{% endif %}
{% set message = 'It is ' + message + 'of ' + now().strftime("%B") + ',. ' %}
{{ message }}
Ok, I found the solution, just put â-â before âHâ and now it is working without zero.
data_template:
message: 'The time is {{now().strftime('%-H')}} o clock.'
try this
I just replace the zero with an âohâ in anything less than 10 so "10 oh five PM instead of âten zero five pmâ everything else sounds OK, a lot less coding
I did something similar to get the response sounding more like a human being, including additional checks for âmidnightâ, âmiddayâ, âmorningâ, âafternoonâ and âeveningâ (the latter after lengthy philosophical discussion about when the afternoon actually becomes the evening). 39 lines of code and countingâŚ
Below is my simple code that will provide a greeting and then announce the time.
My morning starts early thatâs why I have it at 4AM.
type: tts
- media_player.office
message: >-
'{% if now().strftime('%H')|int < 12 and now().strftime('%H')|int > 4 %}
Good morning
{% elif now().strftime('%H')|int >= 12 and now().strftime('%H')|int < 16 %}
Good afternoon
{% else %}
Good evening
{% endif %}. The current time is {{ now().strftime('%I %M %p') }}.
