TTS using built in RPi3 analogue audio output with Hassio?
Haii
Do you try Spotify Extension with this Repo. I have tried but not able to install . i am using rasbery pi 4 .
any idea
hi,
when I try to add the repo to Home Assistant 2021.6.6 I get an error “invalid repo”. is there a way to bypass that? there couple of addons I am interested in …
thank you
I just tried using this link and it works on my RPi3B and 4B
https://github.com/Poeschl/Hassio-Addons
This is a custome media_player component I made, supporting Pi audio output or bluetooth output. You can use it without installing any add-on.
Hi. Guide for install?
Platform error media_player.pulseaudio - Integration ‘pulseaudio’ not found.
You should put all the files in /config/custom_components/pulseaudio/, just like what the other custom integrations do, and restart homeassistant core.
Then, you can config it from the frontend menu config - Integrations, by adding an integration name pulseaudio.
Can't install bestlibre/aarch64-mopidy:0.2.7: 404 Client Error for http+docker://localhost/v1.41/images/create?tag=0.2.7&fromImage=bestlibre%2Faarch64-mopidy&platform=linux%2Farm64: Not Found ("manifest for bestlibre/aarch64-mopidy:0.2.7 not found: manifest unknown: manifest unknown")
RPI4. aarch64
