Ttuya devices stopped updating sensors
Hi there. I added tuya device (extension cable), first through cloud synchronization, official extension. Output switched sockets, and power consumption indicators. After some time, the indicators stopped updating, and they did this only if I went into the proprietary application. I thought that there was some problem with the cloud, and decided to synchronize through local tuya, manually select each value, set it on / off, and similarly displayed energy consumption indicators. Literally 40 minutes, and exactly the same problem - the data simply stopped updating, to update them you need to go to the tuya proprietary application, and only in this case everything is updated. I don’t even know what to sin on here, the server restarted, on / off it works without problems, but there are problems with energy consumption, namely its fixation.
