Tube Tuya motor - Setting motor direction, limits
Hi, I have recently installed A-OK tubular motor running zigbee. I have managed to connect to my network, and can use the up and down to control the blind. But this is where the issue comes in. One of the blinds is going in opposite direction to the button. When I set the motor direction either true or false, it doesn’t seem to change anything. Also, noticed that it doesn’t seem to register any open or closed % which the motor is moving. Hence, I cant set a top or bottom limit. Hoping someone can help as Im sure I’m doing something wrong.
My last resort is to get a Tuya zigbee hub and use the Tuya app to setup and connect to Home Assistant.
Hi, how were you able to connect the motor to Home Assistant without a Tuya Hub?
