TubesZB EFR32 MGM21 PoE Coordinator Matter/Thread Conversion
i have a EFR32 MGM21 PoE Coordinator that i recently replaced with the dual radio mgm24 zwave/zigbee and was wondering if anyone had some pointers on how i could re-flash the old coordinator to be a Thread Border Router?
i believe this is the last version of the yaml i was using, so i’m thinking it would be the zeroconf section that would need to be modified, but i’m really new to the esp32/iot world and would prefer not to get to an un-recoverable state
esphome:
  project:
    version: "3.0"
esp32:
  board: esp-wrover-kit
  framework:
    type: arduino
external_components:
  - source: github://tube0013/esphome-stream-server-v2@testing1
#  - source: github://vallejoyuridamian/esphome-stream-server-v2
  - source: github://syssi/esphome-zeroconf@main
dashboard_import:
  package_import_url: github://tube0013/tube_gateways/models/current/tubeszb-efr32-MGM210-poe/firmware/esphome/tubeszb-efr32-mgm210-poe-2023.yaml
#Olimex ESP32-PoE Ethernet
ethernet:
  type: LAN8720
  mdc_pin: GPIO23
  mdio_pin: GPIO18
  clk_mode: GPIO17_OUT
  phy_addr: 0
  power_pin: GPIO12
    # Optional manual IP
  #manual_ip:
    #static_ip:
    #gateway:
    #subnet: 255.255.255.0
# Enable logging
logger:
  level: DEBUG
# Enable Home Assistant API
api:
  reboot_timeout: 0s
ota:
web_server:
  port: 80
  version: 1
switch:
  - platform: gpio
    pin: 5
    inverted: yes
    restore_mode: ALWAYS_OFF
  - platform: gpio
    pin: 16
    name: "Pull Bootloader pin (PA0) to Low"
    inverted: yes
    disabled_by_default: true
button:
  - platform: restart
    name: "Restart the Gateway"
    on_press:
      - switch.turn_on: zRST_gpio
      - delay: 15ms
      - switch.turn_off: zRST_gpio
uart:
  rx_pin: GPIO36
  tx_pin: GPIO4
  baud_rate: 115200
stream_server:
  uart_id: uart_bus
  port: 6638 # optional, default is 6638
binary_sensor:
  - platform: stream_server
    stream_server: ss
    name: "TubesZB Serial Connected"
zeroconf:
  - service: tubeszb
    protocol: tcp
    port: 6638
    txt:
      version: 1.0
      radio_type: ezsp
      baud_rate: 115200
      data_flow_control: software
i did find this https://esphome.io/components/openthread/ which had the below, but i’m not sure how the poe/ethernet would relay through the thread configuration. additionally, if i did want to disable zigbee what in the previous configuration would i need to eliminate?
# Example OpenThread component configuration
network:
  enable_ipv6: true
openthread:
  device_type: FTD
  channel: 13
  network_name: OpenThread-8f28
  network_key: 0xdfd34f0f05cad978ec4e32b0413038ff
  pan_id: 0x8f28
  ext_pan_id: 0xd63e8e3e495ebbc3
  pskc: 0xc23a76e98f1a6483639b1ac1271e2e27
  mesh_local_prefix: fd53:145f:ed22:ad81::/64
  force_dataset: true
Thanks!!
[edit]
i just found this that might help me get things on track:
https://www.reddit.com/r/MatterProtocol/comments/1i8b8dt/esp_thread_border_router_extend_your_thread/
