Hi all,
After reading a few post on here about flow measurements, I’ve bought a TUF-2000M with the small TS-2 sensors. This is running just fine over modbus with esphome on an ESP32 + RS485 converter. My config is as follows in case you’re also trying to do this:
uart:
tx_pin: GPIO17
rx_pin: GPIO16
baud_rate: 9600
# debug:
# direction: BOTH
modbus:
uart_id: mod_bus_uart
send_wait_time: 500ms
modbus_controller:
- id: tuf2000m
address: 0x1
modbus_id: modbus1
setup_priority: -10
update_interval: 3s # TODO: Default is 60, makes more sense once in prod
- platform: modbus_controller
modbus_controller_id: tuf2000m
name: "${friendly_name} Flow rate"
register_type: holding
address: 0x1 # Register 1
register_count: 2
value_type: FP32
device_class: "volume_flow_rate"
state_class: "measurement"
unit_of_measurement: "g/m"
name: "${friendly_name} Velocity"
address: 0x3 # Register 3
register_count: 2
value_type: FP32
device_class: "speed"
unit_of_measurement: "m/s"
name: "${friendly_name} Positive Accumulator"
address: 0x9 # Register 9
register_count: 2
value_type: FP32
device_class: "water"
unit_of_measurement: "g"
name: "${friendly_name} Flow Meter Temperature #1"
address: 0x21 # Register 33
register_count: 2
value_type: FP32
device_class: "temperature"
unit_of_measurement: "°C"
name: "${friendly_name} Flow Meter Temperature #2"
address: 0x23 # Register 35
register_count: 2
value_type: FP32
name: "${friendly_name} Flow Meter Signal Quality"
address: 0x5C # Register 92
register_count: 1
value_type: U_WORD
lambda: |-
return (uint16_t)(x) & 0xff;
unit_of_measurement: "%"
name: "${friendly_name} Flow Meter Upstream Strength"
address: 0x5D # Register 93
register_count: 1
value_type: U_WORD
lambda: |-
return (x/2048.0)*100.0;
name: "${friendly_name} Flow Meter Downstream Strength"
address: 0x5E # Register 94
register_count: 1
value_type: U_WORD
lambda: |-
binary_sensor:
name: "${friendly_name} Flow Meter Error No Signal"
address: 0x48 # Register 72
bitmask: 0x1
name: "${friendly_name} Flow Meter Error Low Signal"
bitmask: 0x2
name: "${friendly_name} Flow Meter Error Poor Signal"
bitmask: 0x4
name: "${friendly_name} Flow Meter Error Pipe Empty"
bitmask: 0x8
name: "${friendly_name} Flow Meter Error Hardware Failure"
bitmask: 0x10
name: "${friendly_name} Flow Meter Error Gain Ajusting"
bitmask: 0x20
name: "${friendly_name} Flow Meter Error Freq Overflow"
bitmask: 0x40
name: "${friendly_name} Flow Meter Error RAM CS"
bitmask: 0x100
name: "${friendly_name} Flow Meter Error Clock"
bitmask: 0x200
name: "${friendly_name} Flow Meter Error Parameters CS"
bitmask: 0x400
name: "${friendly_name} Flow Meter Error ROM CS"
bitmask: 0x800
name: "${friendly_name} Flow Meter Error Temp Circuits"
bitmask: 0x1000
name: "${friendly_name} Flow Meter Error Internal timer"
bitmask: 0x4000
What I have problems with is getting it to actually work though. I live in the US and have new 1" copper pipe (type L). When measuring these I get an OD of 28.6mm, ID of 26.0mm and a wall thickness of 1.3mm. (A bit thicker than the standard says it should be but that’s a good thing I guess. Plugging in the standard’s numbers makes no real difference.)
When feeding these parameters into the unit I get a distance of ~4mm in V setup and 11mm in a W setup. In either configuration I can get to a signal quality of ~85 with some variance between 78 and 90 over time and fiddling. However neither of these happens at the distance the unit indicates, I’m always a few mm off (it’s actually not clear how to exactly measure but I assume just between the sensors going by the images in the manual).
However going by the manual after this step the next one is to get the TOM/TOS ratio around 100 ±3. In neither setup I’ve gotten anywhere near this. In the V config it was around 111 and in the W config it’s 76%
The resulting flow numbers make no sense at all either. Even with all valves closed I’m running about 0.5 gallon/minute. Zeroing things out doesn’t improve the situation. Large or no flow makes no difference either.
Does anyone have this working by chance? Any tips you can share to get this working would be much appreciated!
