The outcomes of this project are:
- Tune to specific HDHomerun antenna channels using VLC
- Switch between channels
- Use Google Assistant to be able to tune and switch channels
- Create a “Room Remote” using lovelace with channel buttons
Requires the following being functional:
- Integrate NVIDIA SHIELD into Home Assistant using ADB functionality (link)
- Google Assistant Cloud integration (link)
- VLC app installed on the SHIELD
- HDHomerun can tune channels using their app (or a supported variant)
Example of my lovelace room remote:
Step 1: Create a script to kill VLC (required to switch between channels):
Note down the script numbers and how they map to your channels as you’ll need them later to create the room remote.
'1591980710565':
alias: Shield - Family Room - Kill VLC
sequence:
- data:
command: am force-stop org.videolan.vlc
entity_id: media_player.nvidia_shield
service: androidtv.adb_command
mode: single
icon: mdi:vlc
Be sure to update the entity_id as needed throughout
Step 2: Create scripts for each of the channels you want to use:
'1591981093286':
alias: Shield - Family Room - Channel 11.1 (KTVT-DT CBS)
sequence:
- service: script.1591980710565
- data:
command: am start -a android.intent.action.VIEW -d http://192.168.1.XXX:5004/auto/v11.1
-n org.videolan.vlc/.gui.video.VideoPlayerActivity
mode: single
icon: mdi:vlc
Note that you will need to replace the IP address and channel in the above command. You can get the entire URL from here: http://hdhomerun.local/lineup.html on your local network if you don’t know the IP address of your HDHomerun. In your channel list, right-click on the channel number and you can use the copy link option.
Step 3: Make sure scripts are being shared with Google
In the HA UI, Go to Configuration > Home Assistant Cloud > Google Assistant Manage Entities > make sure the scripts are permitted to be exposed to google assistant
Step 4: Setup a routine in Google Assistant
Google Assistant > Routines > Manage Routines > + Add a routine:
Add “When” information: “Turn on channel 11” or “Watch channel 11” or “Turn on CBS” or “Watch CBS”
(or whatever makes sense to you) -
Add “Assistant will” information: Adjust scenes > check the appropriate script from HA
(Mine is “Shield - Family Room - Channel 11.1”)
Step 5 (optional): Add remote button images to config directory:
Place the button images you want to use in the following location:
*/config/www/lovelace
If you don’t want pictures, use whatever else.
Step 6: Create lovelace “Room Remote”:
cards:
- entity: media_player.nvidia_shield
type: media-control
- cards:
- hold_action:
action: call-service
service: script.1591980863361
image: /local/lovelace/kdfw4.jpeg
tap_action:
service: script.1591979439834
type: picture
- hold_action:
image: /local/lovelace/kxas5.jpeg
tap_action:
service: script.1591979439844
type: picture
- hold_action:
image: /local/lovelace/wfaa8.jpeg
tap_action:
service: script.1591979439934
type: picture
- hold_action:
image: /local/lovelace/ktvt11.jpeg
tap_action:
service: script.1591981093286
type: picture
type: horizontal-stack
- cards:
- hold_action:
image: /local/lovelace/kera13.png
tap_action:
service: script.1591979449834
type: picture
- hold_action:
image: /local/lovelace/kera13_2.png
tap_action:
service: script.1591981003176
type: picture
- hold_action:
image: /local/lovelace/kdaf33.jpeg
tap_action:
service: script.1591981003276
type: picture
- hold_action:
image: /local/lovelace/ion68.jpeg
tap_action:
service: script.1591982223627
type: picture
type: vertical-stack
I also created a script to wake up the SHIELD and one to go home and use them in my channel scripts, just in case the SHIELD is sleeping or in another app when I tell google to turn on a channel. They are below:
Wakeup:
'1591980796379':
alias: Shield - Family Room - Wakeup
sequence:
- data:
command: WAKEUP
mode: single
icon: mdi:play-network
Home:
'1591980863361':
alias: Shield - Family Room - Home
sequence:
- data:
command: HOME
mode: single
