TuneIn Radio support
I would like to have support for TuneIn Radio to start playing a music station on a media player.
I know you can get the stream url and use media_player.play_media with media_content_id but when I cast this to my google home hub it:
  • Start very slow compared with starting it via google assistant
  • I have no album art / information on the screen. Just black screen…
It would be nice if there is some way to implement this.
Did you make it somehow?
I’m also very interested to get this running.
Specifically, the buffering speed is annoying me the most.
I have Volumio running on a RP3. It’s audio output is connected to my Monoprice amp on one of the inputs. I select and switch everything through the Home Assistant interface and set up automations to automatically switch inputs on the Amp. It works well and fully supports Tune-in.
I am also looking for this functionality and guessed it should already be available. It seems it is not.
However, I recently came across a ‘Google Relay’ project which basically allows you to pass your voice commands through code directly to the cast device. I will look into it
Check this lovelace card. Easiest to implement radio stations. I have around 7 Google devices that I can cast to them and around 15 different radio stations setup for them. I show logo of station and its title on the Google device with screen. Showing currently playing song is a no go. But I modified the code and implement my own song artist/title display inside the card:
Look at the original card here:
And my changes under issues.
found any workaround over the years?
Hi, have you the solution since years ?
TuneIn is supported by Music Assistant.
how do i add tuneIn into Music Assistant?
Are you running the old version or the Music Assistant 2.0 BETA? If you’re not running the beta I recommend you do. This screenshot is from the BETA. Also the discussion area on the git is a great resource.
Thx. That Addon is great and makes my Spotcast Integration obsolete i guess
I’m getting a 500 error when trying to install the integration… Server seems to be offline.
Using Play Media, I cast different radio stations (url’s) 24/7 to various Chromecasts and Google Home speakers and it is not slow.
Has anybody another solution for this?
Music Assistant doesn’t work well (after a test) and the integrated radiobrowser is a mess. would be better with a search function.
