I just bought and set up the Tuo temperature sensor, which uses Matter over Thread.
The problem is, the temperature is being reported in increments of 1°C, which is lower precision than I’d expect.
The humidity is being reported to the hundredth of a percent, though, so I suspect an issue with the device itself.
Has anyone else used this sensor and seen something similar (or different)?
