I installed Home Assistant Core and I get this message:
2022-02-27 18:01:46 ERROR (MainThread) [homeassistant.components.camera.img_util] Error loading libturbojpeg; Cameras may impact HomeKit performance
File "/Users/server/Documents/homeassistant/lib/python3.9/site-packages/homeassistant/components/camera/img_util.py", line 96, in __init__
TurboJPEGSingleton.__instance = TurboJPEG()
File "/Users/server/Documents/homeassistant/lib/python3.9/site-packages/turbojpeg.py", line 297, in __init__
self.__find_turbojpeg() if lib_path is None else lib_path)
File "/Users/server/Documents/homeassistant/lib/python3.9/site-packages/turbojpeg.py", line 906, in __find_turbojpeg
raise RuntimeError(
RuntimeError: Unable to locate turbojpeg library automatically. You may specify the turbojpeg library path manually.
e.g. jpeg = TurboJPEG(lib_path)
I am pretty sure that the installation ran TurboJPEG. What do I have to do? I am fairly new to Python on virtualenv on Macs.
Ok, that is an option. But Parallels failed already…
But if it will run natively on macOS on Python, I still prefer that to keep it simple.
What exactly are the disadvantages?
With Core I have to update HA and the custom packages manually. Since I use the Mac anyway, I have to update macOS manually as well.
I don‘t need snapshots, I have manual backups.
I guess I can install anything I need (and update manually). It might take more time, but it is doable, right?
Disadvantage is that you need to know how to troubleshoot problems like this - where libraries are missing. That and you need to rebuild the venv every December when the Python deprecation hits. This coming December will see support for Python 3.9 dropped, next December it’ll be 3.10, and so on.
You won’t be able to upgrade it beyond 2022.12 if you’re using Python 3.9. When the first release of 2023 comes out you’ll need to rebuild it with Python 3.10.
That’s basically just removing the existing venv and creating it fresh with Python 3.10.
Ok, so I just need to figure out what I am missing (such as the wrench symbol on the left). Is there a list what I can/have to install to get the most out of HA?
I don’t have the integrated editors and most important no ZWave-JS.
This could be made easier by the developers of HA. Instead suggesting to use a VM is kind of weird.
