Turn a switch LED a different color when door lock is open
I would like to turn the indicator LED on my ZEN71 switch red when a door lock status is “unlocked”. Is there a way to do this?
Yes. Are you running Z-wave JS UI? If you go to the Z-wave UI, click on the device you are interested in, make the following changed:
  • LED indicator to Always On
  • LED Indicator: Confirm Configuration Change to Disable
    Then in the device page you need to enable the LED Indicator Color in configuration.
Here is an automation I am using for this exact purpose:
alias: Side Lock monitor
description: ""
  - platform: device
    device_id: 79de2c039698eed4cd32b1e587c822c3
    domain: lock
    entity_id: d63fd3aa61f0844773c92f185dd36ba4
    type: unlocked
  - platform: device
    domain: lock
    type: locked
condition: []
  - choose:
      - conditions:
          - condition: trigger
            id:
              - Unlocked
        sequence:
          - device_id: b3c74a570c138bc788865029b1395410
            domain: zwave_js
            type: set_config_parameter
            endpoint: 0
            parameter: 23
            bitmask: null
            subtype: 23 (LED Indicator Color) on endpoint 0
            value: 3
      - conditions:
            id:
              - Locked
        sequence:
            domain: zwave_js
            endpoint: 0
            parameter: 23
            bitmask: null
            value: 2
mode: single
