It seems like a common automation and thus solved by quite a few people in this forum already - but apparently none of the solutions corresponds to what I try to achieve:
Trigger:
someone comes home
Condition:
sun is set
no one is home yet
Action:
turn all lights on
Seems fairly straight forward and I came up with the following - except it doesnt work:
- alias: Turn all lights on when sun set and arriving
- entity_id: device_tracker.PersonA
platform: state
to: home
- entity_id: device_tracker.PersonB
platform: state
to: home
condition:
- condition: sun
after: sunset
after_offset: "0:30:00"
- condition: or
conditions:
- condition: state
state: away
- condition: state
state: away
- data:
entity_id: group.all_lights
service: homeassistant.turn_on
Any hints on what I did wrong or how I could debug this (I tried by setting the device_trackerâs and the sunâs state manually but without any effect)?
For detecting whether âanyoneâ is home we use groups. Homeassistant automatically creates group.all_devices for the device tracker group. This group will show home if one or more people are home and away if all devices are away.
So using the state of that group alone is all you need to establish if the person coming home is arriving to an empty house.
(this presumes youâre not using a device tracker platform to ping something that is always at home, if thatâs the case you create a group with the ones you want to use for presence detection and use that instead).
As for the rest of your code, the offset needed to know which way to go with a + / -, and you were calling the entity_id twice in the service of the action, which will probably error.
Cleaning it up looks like thisâŚ
platform: state
entity_id: group.all_devices
to: 'home'
condition:
condition: sun
after: sunset
after_offset: "-00:30:00"
Thanks a lot. I was aware of the group feature but since I use the device tracker not only for âhumansâ (and their phones) put also to see if certain devices (sensors) are still online I didnât use it. But it just crossed my mind that I can create and use a group group.all_phones instead.
Will test it tonight as I figured just out that the sun cannot be overwritten via the interface.
