You should get a popup. If you don’t, go to 192.168.4.1 and fill-in your wifi network name, password, MQTT server IP, and credentials. Click SAVE and connect back to your home wifi.
Looks like you have done everything except “SAVE”.
I’ve used D1mini v 3.0.0, and can’t connect to AP. It says that the password is incorrect.
Can see wifi network “MrDIYNotifier-145574”, but can’t connect (wifi wrong password)
What do i do wrong?
23:33:57.168 → Config size: 357
23:33:57.168 → Wrong config version. Applying defaults.
23:33:57.168 → [iwcAll]
23:33:57.168 → |-- [iwcSys]
23:33:57.168 → | |-- ‘iwcThingName’ with value: ‘MrDIYNotifier-145574’
23:33:57.215 → | |-- ‘iwcApPassword’ with value:
23:33:57.215 → | |-- [iwcWifi0]
23:33:57.215 → | | |-- ‘iwcWifiSsid’ with value: ‘’
23:33:57.215 → | | – ‘iwcWifiPassword’ with value:
23:33:57.215 → | – ‘iwcApTimeout’ with value: ‘30’
23:33:57.215 → |-- [iwcCustom]
23:33:57.215 → | |-- [mqttgroup]
23:33:57.215 → | | |-- ‘mqttServer’ with value: ‘’
23:33:57.215 → | | |-- ‘mqttUser’ with value: ‘’
23:33:57.215 → | | |-- ‘mqttPass’ with value:
23:33:57.215 → | | – ‘mqttTopic (without / at the end)’ with value: ‘’
23:33:57.215 → | – [soundgroup]
23:33:57.215 → | |-- ‘Sound_output’ with value: ‘’
23:33:57.215 → | |-- ‘Sound_Volume’ with value: ‘0.5’
23:33:57.215 → | |-- ‘samVoice :’ with value: ‘’
23:33:57.262 → | – ‘GoogleTTSvoice’ with value: ‘’
23:33:57.262 → – [hidden]
23:33:57.262 →
23:33:57.262 → Using No DAC output on ESP8266, audio output on pins
23:33:57.262 → speaker L & R → GPIO3 (RX)
23:33:57.262 → Don’t try and drive the speaker pins can’t give enough current to drive even a headphone well and you may end up damaging your device
23:33:57.262 → SkipApStartup is requested, but either no WiFi was set up, or configButton was pressed.
23:33:57.262 → AP password was not set in configuration
23:33:57.262 → State changing from: 0 to 1
23:33:57.262 → Setting up AP: MrDIYNotifier-145574
23:33:57.309 → With default password:
23:33:58.152 → AP IP address: 192.168.4.1
23:33:58.152 → AP password was not set.
23:33:58.152 → WiFi SSID was not set.
23:33:58.152 → Will stay in AP mode.
23:33:58.152 → State changed from: 0 to 1
23:33:59.559 → [MQTT] /status idle
This is a GREAT post! I was looking for a way to get notifications without the need of an intermediary like Alexa or Google Assistant. I have been able to successfully flash the D1 Mini with “MrDIY_notifier_custom_MQTT.bin” file. I go through the process of AP configuration, and all goes smoothly:
For Access Point Password I put “mrdiy.ca” and for the MQTT Server, I put the IP of my home assistant server (10.0.0.171), my MQTT USER and MQTT Password (which I added as a user). For the MQTT Topic I add the “/mrdiynotifier”.
I then restart my mqtt broker, wait a minute for it to start and then I plug the D1 Mini to a speaker and plug the USB to power, I hear the connection sound that indicates connection to WIFI and MQTT server. After hearing the connection sound, I can see the following mqtt log (although I keep refreshing, and connecting back again the D1 Mini (hearing the sound), I cannot see anything coming up as MrDIy Notifier in the mqtt log):
I have decided to completely uninstall my Mosquitto broker from my home assistant adds-on, and I have disabled my Wyze Docker Bridge (it was using mqtt to discover cameras in my home). Then I uninstalled my Core-Mosquitto MQTT from my integrations, and proceeded to restart my server.
I then re-installed my Mosquitto broker and restarted my HA server again. When restarted, a new integration MQTT was discovered and I configured it. The following default configuration is shown:
Perhaps you missed this, as you named your user homeassistant
Create a new user for MQTT via your Home Assistant’s frontend Configuration → Users (manage users) , (i.e. not on Mosquitto’s Configuration tab). Notes:
This name cannot be homeassistant or addons, those are reserved usernames.
If you do not see the option to create a new user, ensure that Advanced Mode is enabled in your Home Assistant profile.
For the username, I created a user (user: mqttuser ; password: mqttpassord in the homeassistant users configuration). That is the user I add to the AP configuration:
You probably need to read a good MQTT primer, but basically MQTT communicates outward by a client (HA) subscribing to a topic. The other device (the esp) publishes to the topic. MQTT is a kind of postbox. See Beginners Guide To The MQTT Protocol
I have built a media player using a DAC and esp32. All seems fine but I don’t have an entity associated with the player so I can’t play to it.
Any ideas?
Here is the main part of the code.
media_player:
- platform: i2s_audio
name: Media Player 1
dac_type: external
i2s_lrclk_pin: GPIO33
i2s_dout_pin: GPIO22
i2s_bclk_pin: GPIO19
mode: mono
