Turn Boolean on using trigger slot
I know you can use a trigger slot to fill in a name on a sensor, for example I use…
platform: conversation
command:
  - Where is {name}
If I say where is Andrew, it then responds using
{{ states('sensor.' ~ trigger.slots.name | lower | replace('?', '') ~ 'cl') }}
Where sensor.andrewcl is a sensor that says where I am… As below…
  - name: "andrewcl"
    unique_id: 230207031515
    state: >-
        {% if is_state('sensor.where_is_andrew', 'dining') %}
        Andrew is in the Dining Room.
        {% else %}
        Sorry, Andrew is nowhere to be found.
        {% endif %}
Works wonderfully… there is one for each person in the house.
Now I would like to do a simar thing with Booleans, I have a Boolean for each person, when turned on it would run an automation specific to that person.
So I would use
command:
  - {name} is using the Gym
And be able to trigger the correct Boolean… Just not sure of the syntax if someone can help… I am thinking something like below
service: input_boolean.turn_on
metadata: {}
data: {}
  entity_id: 'input_boolean.gym_setup_' ~  trigger.slots.name
Hope this makes sense…
try “input_boolean.gym_setup_{{trigger.slots.name}}”
It is convenient to experiment with similar values in dev tools - template
Any of these would work.
entity_id: input_boolean.gym_setup_{{trigger.slots.name}}
entity_id: "{{ 'input_boolean.gym_setup_' ~ trigger.slots.name }}"
entity_id: >
Brilliant, thank you
