I have a Tasmota connected to my coffee machine but sometimes I forget it on. Is there a way to shut it down after being turned on for a period of time?
There’s a for:
option with a state trigger.
This is my automation, exactly for this:
- id: rocket_stop
alias: Rocket stoppen
- entity_id: switch.sonoff_rocket_relay
for: 03:00:00
platform: state
to: 'on'
- data:
service: switch.turn_off
Thank you both!
Before trying the script from @paddy0174 I opened up the automation UI and could set it up really quickly without any typing:
You know that you can do “both” with automations? Mine is set up via UI as well, and this is the code, that was generated in automations.yaml
. I just go into automations.yaml
afterwards and change the id from the numerical one to a “readable id”. In fact you can paste this simply into your automations.yaml
save and reload automations
, and then find it in the UI to make changes.
Yes, but I thought I had to manually enter the script and copy/paste the entity id. Almost all my other automations cannot be properly edited from the UI (such as demultiplexers), but this one works a treat.
