Hello Guys,
I’m not new to HA but can not get it work…
I want to turn on my heating when comming home, but only in those rooms where my window sensor is off (closed).
My scripts:
set_bad_temp_home:
sequence:
- service: climate.set_temperature
data_template:
entity_id: climate.oeq1686946
temperature: 21.5
set_kuche_temp_home:
sequence:
data_template:
entity_id: climate.oeq1685747
temperature: 21.5
set_wohnzimmer_temp_home:
sequence:
data_template:
entity_id: climate.oeq1684915
temperature: 21.5
My automation for this:
- alias: 'Heizung_home_on'
initial_state: True
platform: state
entity_id: group.devices
to: 'home'
condition:
condition: and
conditions:
- condition: state
entity_id: input_boolean.heizung
state: 'on'
- condition: numeric_state
entity_id: sensor.yweather_temperature
below: '15'
- service: script.turn_on
data_template:
entity_id: >
{% if is_state('binary_sensor.oeq1376840_state', 'off') %}
script.set_bad_temp_home
{% endif %}
data_template:
entity_id: >
{% if is_state('binary_sensor.oeq1027067_state', 'off') %}
script.set_kuche_temp_home
{% endif %}
data_template:
entity_id: >
{% if is_state('binary_sensor.oeq1375758_state', 'off') %}
script.set_wohnzimmer_temp_home
{% endif %}
My Error HA gave me:
Error while executing automation automation.heizung_home_on. Invalid data for call_service at pos 1: Entity ID is an invalid entity id for dictionary value @ data['entity_id']
Triggering the scripts manually works fine.
Any ideas ? Every help is very appreciated.
Thanks!
