Here’s my “Light and Motion automations” tab in node red, with quite a few flows in there that do what you want, in a few different way, maybe it will help you to see how others are doing it, and give some inspiration. If you don’t know, go to the top right hamburger menu, import from clipboard (after copying the code I pasted) to import my flows to look at. If you decide to use any of them, you’ll just need to change the server and any entities in the nodes.
Look at my flood light automation. That’s the most basic “Light On -> X amount of time -> Light Off.” way to do it. If you have motion sensor(s) you can use them to further enhance the automation. Look at my Garage automation. Light comes on if "Garage Door opens OR Garage-Utility Door is opened OR motion is detected. If no motion after trigger, turn off garage light after 10 mins (close garage door after 20). IF motion or any doors open during the 10 or 20 minute timers, the timers reset, and continue to reset until the triggers no longer happen. I work in the garage a lot, and I use this automation probably more than any other currently.
There are probably better ways to do what I’m doing, but I can say that my flows work.
[{"id":"e89db148.97c89","type":"subflow","name":"Garage doors open? Motion?","info":"","category":"","in":[],"out":[{"x":440,"y":100,"wires":[{"id":"2277c408.f3fbcc","port":0},{"id":"255daffa.19a3e","port":0},{"id":"1d413393.d37cac","port":0}]},{"x":440,"y":200,"wires":[{"id":"1d413393.d37cac","port":0}]}],"env":[]},{"id":"255daffa.19a3e","type":"server-state-changed","z":"e89db148.97c89","name":"Garage Door Open","server":"26956a45.92d866","version":1,"entityidfilter":"cover.door_garage","entityidfiltertype":"exact","outputinitially":false,"state_type":"str","haltifstate":"open","halt_if_type":"str","halt_if_compare":"is","outputs":2,"output_only_on_state_change":false,"x":190,"y":160,"wires":[[],[]]},{"id":"1d413393.d37cac","type":"server-state-changed","z":"e89db148.97c89","name":"Garage Motion","server":"26956a45.92d866","version":1,"entityidfilter":"binary_sensor.motion_garage","entityidfiltertype":"exact","outputinitially":false,"state_type":"str","haltifstate":"on","halt_if_type":"str","halt_if_compare":"is","outputs":2,"output_only_on_state_change":false,"x":180,"y":220,"wires":[[],[]]},{"id":"2277c408.f3fbcc","type":"server-state-changed","z":"e89db148.97c89","name":"Utility-Garage Door","server":"26956a45.92d866","version":1,"entityidfilter":"binary_sensor.interior_door_utility_garage","entityidfiltertype":"exact","outputinitially":false,"state_type":"str","haltifstate":"on","halt_if_type":"str","halt_if_compare":"is","outputs":2,"output_only_on_state_change":false,"x":190,"y":100,"wires":[[],[]]},{"id":"66fa4263.305cdc","type":"subflow","name":"Dining light on & motion?","info":"","category":"","in":[],"out":[{"x":500,"y":140,"wires":[{"id":"ffaec90f.b85168","port":0},{"id":"25cccb7a.0a4c34","port":0}]}],"env":[],"status":{"x":500,"y":200,"wires":[{"id":"25cccb7a.0a4c34","port":0},{"id":"ffaec90f.b85168","port":0}]}},{"id":"ffaec90f.b85168","type":"poll-state","z":"66fa4263.305cdc","name":"Dining light on?","server":"26956a45.92d866","version":1,"updateinterval":"11","updateIntervalUnits":"minutes","outputinitially":false,"outputonchanged":false,"entity_id":"light.dining","state_type":"str","halt_if":"on","halt_if_type":"str","halt_if_compare":"is","outputs":2,"x":300,"y":180,"wires":[[],[]]},{"id":"25cccb7a.0a4c34","type":"server-state-changed","z":"66fa4263.305cdc","name":"Dining motion","server":"26956a45.92d866","version":1,"entityidfilter":"binary_sensor.motion_dining","entityidfiltertype":"exact","outputinitially":false,"state_type":"str","haltifstate":"on","halt_if_type":"str","halt_if_compare":"is","outputs":2,"output_only_on_state_change":false,"x":310,"y":140,"wires":[[],[]]},{"id":"21a7690.31b8b98","type":"subflow","name":"Before or after bedtime?","info":"","category":"","in":[{"x":160,"y":160,"wires":[{"id":"59a60478.4e4e2c"}]}],"out":[{"x":520,"y":140,"wires":[{"id":"59a60478.4e4e2c","port":0}]},{"x":520,"y":260,"wires":[{"id":"9681f55e.fa2638","port":0}]}],"env":[{"name":"Before bed","type":"str","value":"on"},{"name":"After bed","type":"str","value":"on"}]},{"id":"59a60478.4e4e2c","type":"time-range-switch","z":"21a7690.31b8b98","name":"Dark before bedtime","lat":"27.918805","lon":"-81.866830","startTime":"sunset","endTime":"21:30","startOffset":"","endOffset":0,"x":320,"y":160,"wires":[[],["9681f55e.fa2638"]]},{"id":"9681f55e.fa2638","type":"time-range-switch","z":"21a7690.31b8b98","name":"Dark after bedtime.","lat":"27.918805","lon":"-81.866830","startTime":"21:30","endTime":"sunrise","startOffset":"","endOffset":0,"x":310,"y":240,"wires":[[],[]]},{"id":"1c34dbe2.0fe654","type":"tab","label":"Light and Motion automations","disabled":false,"info":""},{"id":"1a98781f.624118","type":"comment","z":"1c34dbe2.0fe654","name":"1. (Below) If it's dark out, and the Pendant and TV lights are off, turn on kitchen can 1 and 3 to 12% for 12 seconds on motion","info":"","x":440,"y":20,"wires":[]},{"id":"cf2966ee.d64158","type":"api-call-service","z":"1c34dbe2.0fe654","name":"Entryway Lights on (10%)","server":"26956a45.92d866","version":1,"service_domain":"light","service":"turn_on","entityId":"light.entryway","data":"{\"brightness_pct\":16, \"transition\":1}","dataType":"json","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":630,"y":260,"wires":[["865c30ae.244c9"]]},{"id":"1fa06a68.dc1d26","type":"comment","z":"1c34dbe2.0fe654","name":"2. (Below) If it's dark out, turn on the Entryway Lights lights to 20% for 5 seconds. Turns it off if left on for more than 3 minutes with no motion.","info":"","x":480,"y":160,"wires":[]},{"id":"865c30ae.244c9","type":"stoptimer","z":"1c34dbe2.0fe654","duration":"20","units":"Second","payloadtype":"num","payloadval":"off","name":"20sec","x":850,"y":220,"wires":[[],["d27d015b.bea6a"]]},{"id":"d27d015b.bea6a","type":"api-call-service","z":"1c34dbe2.0fe654","name":"Entryway lights off","server":"26956a45.92d866","version":1,"service_domain":"light","service":"turn_off","entityId":"light.entryway","data":"","dataType":"json","mergecontext":"","output_location":"payload","output_location_type":"msg","mustacheAltTags":false,"x":1010,"y":220,"wires":[["25a97947.b91516"]]},{"id":"2badccd1.869a44","type":"api-call-service","z":"1c34dbe2.0fe654","name":"Entryway Lights on (100%)","server":"26956a45.92d866","version":1,"service_domain":"light","service":"turn_on","entityId":"light.entryway","data":"{\"brightness_pct\":100, \"transition\":1}","dataType":"json","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":640,"y":200,"wires":[["865c30ae.244c9"]]},{"id":"91dad229.934d5","type":"server-state-changed","z":"1c34dbe2.0fe654","name":"Entryway Motion Sensor","server":"26956a45.92d866","version":1,"entityidfilter":"sensor.entryway_burglar","entityidfiltertype":"exact","outputinitially":false,"state_type":"num","haltifstate":"8","halt_if_type":"num","halt_if_compare":"is","outputs":2,"output_only_on_state_change":false,"x":130,"y":220,"wires":[["afc21914.26d048","3256b9a.39c2046"],[]]},{"id":"54cd3aba.188ff4","type":"api-call-service","z":"1c34dbe2.0fe654","name":"Turn on Garage Light","server":"26956a45.92d866","version":1,"service_domain":"light","service":"turn_on","entityId":"light.garage","data":"","dataType":"json","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":380,"y":420,"wires":[["329765f.69be89a"]]},{"id":"329765f.69be89a","type":"stoptimer","z":"1c34dbe2.0fe654","duration":"10","units":"Minute","payloadtype":"num","payloadval":"0","name":"10min","x":550,"y":420,"wires":[["4ab4963b.572db8"],[]]},{"id":"4ab4963b.572db8","type":"api-call-service","z":"1c34dbe2.0fe654","name":"Turn off Garage Light","server":"26956a45.92d866","version":1,"service_domain":"light","service":"turn_off","entityId":"light.garage","data":"","dataType":"json","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":720,"y":420,"wires":[[]]},{"id":"e3edaed7.e3a87","type":"comment","z":"1c34dbe2.0fe654","name":"3. (Below) This turns on the garage light when either door is open, or there is motion. Also closes the Garage Door after 45 minutes of no motion.","info":"","x":500,"y":380,"wires":[]},{"id":"f54644b9.5d0f28","type":"api-call-service","z":"1c34dbe2.0fe654","name":"Turn off dining room light","server":"26956a45.92d866","version":1,"service_domain":"light","service":"turn_off","entityId":"light.dining","data":"","dataType":"json","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":670,"y":580,"wires":[["db57f91.8771908"]]},{"id":"89cc180c.711568","type":"api-current-state","z":"1c34dbe2.0fe654","name":"Dining light on?","server":"26956a45.92d866","version":1,"outputs":2,"halt_if":"on","halt_if_type":"str","halt_if_compare":"is","override_topic":false,"entity_id":"light.dining","state_type":"str","state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","blockInputOverrides":false,"x":460,"y":580,"wires":[["f54644b9.5d0f28"],[]]},{"id":"36d66685.541b5a","type":"stoptimer","z":"1c34dbe2.0fe654","duration":"10","units":"Minute","payloadtype":"num","payloadval":"0","name":"10min","x":310,"y":580,"wires":[["89cc180c.711568"],[]]},{"id":"ba0a68e3.4ca4f8","type":"comment","z":"1c34dbe2.0fe654","name":"4. (Below) If the dining room light is left on, turn it off if no motion for 10 minutes","info":"","x":300,"y":540,"wires":[]},{"id":"eab6f81e.668b58","type":"api-call-service","z":"1c34dbe2.0fe654","name":"Turn off entryway light","server":"26956a45.92d866","version":1,"service_domain":"light","service":"turn_off","entityId":"light.entryway","data":"","dataType":"json","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":880,"y":320,"wires":[["25a97947.b91516"]]},{"id":"75d1d3c4.21a2bc","type":"api-current-state","z":"1c34dbe2.0fe654","name":"Entryway light on?","server":"26956a45.92d866","version":1,"outputs":2,"halt_if":"on","halt_if_type":"str","halt_if_compare":"is","override_topic":false,"entity_id":"light.entryway","state_type":"str","state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","blockInputOverrides":false,"x":550,"y":320,"wires":[["654e90dc.96d4d"],[]]},{"id":"7d6156ec.bb54b8","type":"poll-state","z":"1c34dbe2.0fe654","name":"Entryway light on?","server":"26956a45.92d866","version":1,"updateinterval":"8","updateIntervalUnits":"minutes","outputinitially":false,"outputonchanged":false,"entity_id":"light.entryway","state_type":"str","halt_if":"on","halt_if_type":"str","halt_if_compare":"is","outputs":2,"x":110,"y":320,"wires":[["afc21914.26d048"],[]]},{"id":"654e90dc.96d4d","type":"stoptimer","z":"1c34dbe2.0fe654","duration":"3","units":"Minute","payloadtype":"num","payloadval":"off","name":"3min","x":710,"y":320,"wires":[[],["eab6f81e.668b58"]]},{"id":"afc21914.26d048","type":"time-range-switch","z":"1c34dbe2.0fe654","name":"Sunrise to 9:30p","lat":"27.918805","lon":"-81.866830","startTime":"sunrise","endTime":"21:30","startOffset":"","endOffset":0,"x":360,"y":320,"wires":[["75d1d3c4.21a2bc"],[]]},{"id":"3d46e524.01b9ca","type":"stoptimer","z":"1c34dbe2.0fe654","duration":"20","units":"Minute","payloadtype":"num","payloadval":"0","name":"20mins","x":340,"y":480,"wires":[["728ac417.97ddfc"],[]]},{"id":"33335f26.f50e","type":"api-call-service","z":"1c34dbe2.0fe654","name":"Close the Garage","server":"26956a45.92d866","version":1,"service_domain":"cover","service":"close_cover","entityId":"cover.door_garage","data":"","dataType":"json","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":730,"y":480,"wires":[["300efa74.7f29f6","d7885b21.ec31f8"]]},{"id":"300efa74.7f29f6","type":"api-call-service","z":"1c34dbe2.0fe654","name":"Send Pushover Notification","server":"26956a45.92d866","version":1,"service_domain":"notify","service":"pushover","entityId":"","data":"{\"message\":\"No one's been in the garage for some time, so I'm closing the garage door.\",\"title\":\"Home Assistant\"}","dataType":"json","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":1020,"y":420,"wires":[[]]},{"id":"728ac417.97ddfc","type":"api-current-state","z":"1c34dbe2.0fe654","name":"Garage Door open?","server":"26956a45.92d866","version":1,"outputs":2,"halt_if":"open","halt_if_type":"str","halt_if_compare":"is","override_topic":false,"entity_id":"cover.door_garage","state_type":"str","state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","blockInputOverrides":false,"x":520,"y":480,"wires":[["33335f26.f50e"],[]]},{"id":"9f9c38c2.de7208","type":"api-call-service","z":"1c34dbe2.0fe654","name":"Set volume 50%","server":"26956a45.92d866","version":1,"service_domain":"media_player","service":"volume_set","entityId":"media_player.kitchen_hub","data":"{\"volume_level\":0.5}","dataType":"json","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":1220,"y":480,"wires":[[]]},{"id":"d7885b21.ec31f8","type":"time-range-switch","z":"1c34dbe2.0fe654","name":"","lat":"27.918805","lon":"-81.866830","startTime":"07:00","endTime":"21:30","startOffset":0,"endOffset":0,"x":970,"y":480,"wires":[["9f9c38c2.de7208"],[]]},{"id":"1f8c6712.5635e9","type":"api-call-service","z":"1c34dbe2.0fe654","name":"Kitchen night lights off","server":"26956a45.92d866","version":1,"service_domain":"light","service":"turn_off","entityId":"group.kitchen_night_lights","data":"","dataType":"json","mergecontext":"","output_location":"payload","output_location_type":"msg","mustacheAltTags":false,"x":940,"y":120,"wires":[["bdcadc9.daafe2"]]},{"id":"2047cab6.18db96","type":"time-range-switch","z":"1c34dbe2.0fe654","name":"","lat":"27.918805","lon":"-81.866830","startTime":"sunset","endTime":"sunrise","startOffset":0,"endOffset":0,"x":280,"y":80,"wires":[["34910db2.252082"],[]]},{"id":"cc7a69e7.973ce8","type":"api-call-service","z":"1c34dbe2.0fe654","name":"Kitchen night lights on (10%)","server":"26956a45.92d866","version":1,"service_domain":"light","service":"turn_on","entityId":"group.kitchen_night_lights","data":"{\"brightness_pct\":10,\"transition\":3}","dataType":"json","mergecontext":"","output_location":"payload","output_location_type":"msg","mustacheAltTags":false,"x":860,"y":60,"wires":[["56f5b15c.e65d3"]]},{"id":"34910db2.252082","type":"api-current-state","z":"1c34dbe2.0fe654","name":"TV lights off?","server":"26956a45.92d866","version":1,"outputs":2,"halt_if":"off","halt_if_type":"str","halt_if_compare":"is","override_topic":false,"entity_id":"light.tv_strip","state_type":"str","state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","blockInputOverrides":false,"x":450,"y":60,"wires":[["1f29b8fb.7b40a7"],[]]},{"id":"56f5b15c.e65d3","type":"stoptimer","z":"1c34dbe2.0fe654","duration":"15","units":"Second","payloadtype":"str","payloadval":"off","name":"20sec","x":770,"y":120,"wires":[[],["1f8c6712.5635e9"]]},{"id":"1f29b8fb.7b40a7","type":"api-current-state","z":"1c34dbe2.0fe654","name":"Pendant lights off?","server":"26956a45.92d866","version":1,"outputs":2,"halt_if":"off","halt_if_type":"str","halt_if_compare":"is","override_topic":false,"entity_id":"light.pendants","state_type":"str","state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","blockInputOverrides":false,"x":630,"y":60,"wires":[["cc7a69e7.973ce8"],[]]},{"id":"afe355cc.cf0da8","type":"server-state-changed","z":"1c34dbe2.0fe654","name":"Kitchen Motion","server":"26956a45.92d866","version":1,"entityidfilter":"sensor.kitchen_motion_burglar","entityidfiltertype":"exact","outputinitially":false,"state_type":"num","haltifstate":"8","halt_if_type":"num","halt_if_compare":"is","outputs":2,"output_only_on_state_change":false,"x":100,"y":80,"wires":[["2047cab6.18db96"],[]]},{"id":"3256b9a.39c2046","type":"subflow:21a7690.31b8b98","z":"1c34dbe2.0fe654","name":"Dark before or after 9p?","env":[],"x":390,"y":220,"wires":[["2badccd1.869a44"],["cf2966ee.d64158"]]},{"id":"39e222ed.d0a99e","type":"server-state-changed","z":"1c34dbe2.0fe654","name":"Slider","server":"26956a45.92d866","version":1,"entityidfilter":"binary_sensor.door_slider","entityidfiltertype":"exact","outputinitially":false,"state_type":"str","haltifstate":"on","halt_if_type":"str","halt_if_compare":"is","outputs":2,"output_only_on_state_change":true,"x":70,"y":680,"wires":[["ec731d53.65241"],["b90160f.99fa6a"]]},{"id":"56f9ab6d.0de004","type":"api-call-service","z":"1c34dbe2.0fe654","name":"Flood Light On (100%)","server":"26956a45.92d866","version":1,"service_domain":"light","service":"turn_on","entityId":"light.flood","data":"{\"brightness_pct\":100}","dataType":"json","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":520,"y":680,"wires":[[]]},{"id":"695ae40d.19593c","type":"api-call-service","z":"1c34dbe2.0fe654","name":"Flood Light Off","server":"26956a45.92d866","version":1,"service_domain":"light","service":"turn_off","entityId":"light.flood","data":"","dataType":"json","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":560,"y":740,"wires":[["10804473.0fbddc"]]},{"id":"ec731d53.65241","type":"time-range-switch","z":"1c34dbe2.0fe654","name":"","lat":"27.918805","lon":"-81.866830","startTime":"sunset","endTime":"sunrise","startOffset":0,"endOffset":0,"x":260,"y":680,"wires":[["56f9ab6d.0de004"],[]]},{"id":"e0b1c840.a69918","type":"comment","z":"1c34dbe2.0fe654","name":"If it's dark out, turn on the Flood light for 10 minutes when the Slider is opened. ","info":"","x":290,"y":640,"wires":[]},{"id":"b90160f.99fa6a","type":"api-current-state","z":"1c34dbe2.0fe654","name":"Flood light on?","server":"26956a45.92d866","version":1,"outputs":2,"halt_if":"on","halt_if_type":"str","halt_if_compare":"is","override_topic":false,"entity_id":"light.flood","state_type":"str","state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","blockInputOverrides":false,"x":260,"y":740,"wires":[["28767c25.741fd4"],[]]},{"id":"93485c67.c5a69","type":"subflow:66fa4263.305cdc","z":"1c34dbe2.0fe654","name":"","env":[],"x":130,"y":580,"wires":[["36d66685.541b5a"]]},{"id":"9a5a4e8b.5a4a3","type":"debug","z":"1c34dbe2.0fe654","name":"","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":850,"y":660,"wires":[]},{"id":"788c3af4.909524","type":"subflow:e89db148.97c89","z":"1c34dbe2.0fe654","name":"","env":[],"x":140,"y":460,"wires":[["54cd3aba.188ff4"],["3d46e524.01b9ca","329765f.69be89a"]]},{"id":"a84d4de2.b0f72","type":"api-current-state","z":"1c34dbe2.0fe654","name":"Entryway light off?","server":"26956a45.92d866","version":1,"outputs":2,"halt_if":"off","halt_if_type":"str","halt_if_compare":"is","override_topic":false,"entity_id":"light.entryway","state_type":"str","state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","blockInputOverrides":false,"x":1410,"y":260,"wires":[[],["fa2dc429.320478"]]},{"id":"fa2dc429.320478","type":"api-call-service","z":"1c34dbe2.0fe654","name":"Entryway lights off","server":"26956a45.92d866","version":1,"service_domain":"light","service":"turn_off","entityId":"light.entryway","data":"","dataType":"json","mergecontext":"","output_location":"payload","output_location_type":"msg","mustacheAltTags":false,"x":1610,"y":260,"wires":[["a84d4de2.b0f72"]]},{"id":"c4852ac5.a753f8","type":"api-current-state","z":"1c34dbe2.0fe654","name":"Kitchen lights off?","server":"26956a45.92d866","version":1,"outputs":2,"halt_if":"off","halt_if_type":"str","halt_if_compare":"is","override_topic":false,"entity_id":"group.kitchen_lights","state_type":"str","state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","blockInputOverrides":false,"x":1290,"y":120,"wires":[[],["5075ccc9.0f8384"]]},{"id":"5075ccc9.0f8384","type":"api-call-service","z":"1c34dbe2.0fe654","name":"Kitchen night lights off","server":"26956a45.92d866","version":1,"service_domain":"light","service":"turn_off","entityId":"group.kitchen_night_lights","data":"","dataType":"json","mergecontext":"","output_location":"payload","output_location_type":"msg","mustacheAltTags":false,"x":1500,"y":120,"wires":[["c4852ac5.a753f8"]]},{"id":"28fda671.2a16da","type":"api-current-state","z":"1c34dbe2.0fe654","name":"Dining light off?","server":"26956a45.92d866","version":1,"outputs":2,"halt_if":"off","halt_if_type":"str","halt_if_compare":"is","override_topic":false,"entity_id":"light.dining","state_type":"str","state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","blockInputOverrides":false,"x":1020,"y":580,"wires":[[],["a1290c49.3072d"]]},{"id":"a1290c49.3072d","type":"api-call-service","z":"1c34dbe2.0fe654","name":"Dining light off","server":"26956a45.92d866","version":1,"service_domain":"light","service":"turn_off","entityId":"light.dining","data":"","dataType":"json","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":1200,"y":580,"wires":[["28fda671.2a16da"]]},{"id":"b4d7c7ba.dd9028","type":"api-current-state","z":"1c34dbe2.0fe654","name":"Flood light off?","server":"26956a45.92d866","version":1,"outputs":2,"halt_if":"off","halt_if_type":"str","halt_if_compare":"is","override_topic":false,"entity_id":"light.flood","state_type":"str","state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","blockInputOverrides":false,"x":880,"y":740,"wires":[[],["d2599eb8.fa79b"]]},{"id":"d2599eb8.fa79b","type":"api-call-service","z":"1c34dbe2.0fe654","name":"Flood light off","server":"26956a45.92d866","version":1,"service_domain":"light","service":"turn_off","entityId":"light.flood","data":"","dataType":"json","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":1060,"y":740,"wires":[["b4d7c7ba.dd9028"]]},{"id":"bdcadc9.daafe2","type":"delay","z":"1c34dbe2.0fe654","name":"1sec","pauseType":"delay","timeout":"1","timeoutUnits":"seconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"x":1114,"y":121,"wires":[["c4852ac5.a753f8"]]},{"id":"25a97947.b91516","type":"delay","z":"1c34dbe2.0fe654","name":"1sec","pauseType":"delay","timeout":"1","timeoutUnits":"seconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"x":1230,"y":260,"wires":[["a84d4de2.b0f72"]]},{"id":"db57f91.8771908","type":"delay","z":"1c34dbe2.0fe654","name":"1sec","pauseType":"delay","timeout":"1","timeoutUnits":"seconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"x":850,"y":580,"wires":[["28fda671.2a16da"]]},{"id":"10804473.0fbddc","type":"delay","z":"1c34dbe2.0fe654","name":"1sec","pauseType":"delay","timeout":"1","timeoutUnits":"seconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"x":710,"y":740,"wires":[["b4d7c7ba.dd9028"]]},{"id":"28767c25.741fd4","type":"delay","z":"1c34dbe2.0fe654","name":"10min","pauseType":"delay","timeout":"10","timeoutUnits":"minutes","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"x":410,"y":740,"wires":[[]]},{"id":"26956a45.92d866","type":"server","z":"","name":"Hass.io","legacy":false,"hassio":true,"rejectUnauthorizedCerts":true,"ha_boolean":"y|yes|true|on|home|open","connectionDelay":true}]
