Turn light/switch OFF if forgot, based on not detected motion (with time range condition)
Based on system HA motion activated light but improved with only off option.
I manually turn on a switch but if i forgot i needed to automatically turn it off after amount of time with no motion detected.
For example i use this blueprint for turn off my heavy consuming appliances (controlled by a smart switch)
More info here on GitHub Repo
blueprint:
  name: Motion-activated Light Switch Off only
  description: Turn off a switch when motion is not detected anymore.
  domain: automation
  source_url: https://github.com/fabiosoft/HA-Motion-deactivated-Light-Switch/
  input:
    motion_entity:
      selector:
        entity:
          domain: binary_sensor
          device_class: motion
    light_target:
      selector:
          entity:
            domain: switch
    no_motion_wait:
      description: Time to leave the light on after last motion is detected.
      default: 120
      selector:
        number:
          min: 0
          max: 3600
          unit_of_measurement: seconds
    start_time:
      description: Time action should start
      default: "17:00:00"
      selector:
        time:
    end_time:
      default: "00:00:00"
      description: Time action should stop
      selector:
        time:
# If motion is detected within the delay,
# we restart the script.
mode: restart
max_exceeded: silent
  platform: state
  entity_id: !input motion_entity
  to: "on"
condition:
  alias: "Time 17~00"
  condition: time
  # At least one of the following is required.
  after: !input start_time
  before: !input end_time
  #- service: switch.turn_on
  #  target: !input light_target
  - wait_for_trigger:
      platform: state
      to: "off"
  - delay: !input no_motion_wait
  - service: switch.turn_off
Hi, the description shows that the automation is for LIGHT/SWITCH but I am only able to select switches as the device to turn off.
Can you change this?
Hello.
this is a great blueprint. but i have a question. i want to set it that if there is no motion it should turn of the lights after 10 mins, but the question if there was movement with in those 10 mins will the timer start again or it will turn off after 10 mins from the first time there was no movement?
Hi good day, This bluprint is exactly what i was looking for as (new) HA user. I have an IKEA hub integrated via Matter. This so i keep all lights online while playing with HA. Via the IKEA Dirigera hub i have the new Matter (round) motion sensor connected, it shows in HA under devices as matter device (i shared it) and i can see motion detected, voltage lux. so that seems to work. for the light switch i connected the Sonoff build in switch and also connected it to the IKEA hub. this also can be seen and controlled under devices. however…
When i load the blue print i can not select the motion sensor and neither the light switch… I only see one motion sensor, it seems to look for ‘entities’ and not devices. Aslo the light can not be found, only switches like the several IKEA power plugs.
what should i do??
