Turn off a binary sensor in an automation (like in "Developer Tools")
Hi everyone,
I have an issue with a binary_sensor (zwave Motion sensor) from Steinel (IS-140-2).
Every now and then it hangs on detected which leads to the occupancy to stay on as well.
With the developer tools I can reset the sensor to clear (off), but not in an automation.
I have also tried the generic turn off"
Is there no option to manually change a binary_sensor?
A sensor is something that senses. if you want to change it … you need an input_boolean or so. Create a helper as input_bolean. Create an automation which changes the input_boolean whenever the sensor changes.
Thanks, Ralf,
I have read about this option.
However, it’s about a real (motion) sensor, which keeps the state detected every now and then.
That’s causing the occupancy in the garden to be constantly on.
If I reset the sensor manually by usung the developer tools, the occupancy is going back to normal.
I know that this is not how it’ supposed to be, but it’s a workaround to deal with the buggy Steinel Sensor.
A power cycle does help as well, but I don’t have the option (yet) to automate this.
I thought, because it’s possible with the developer tools, it might be with the automation as well…
