Hello Guys,
I have an esp8266 (d1 mini) which controls the gas heater with a relay works as a wifi termostat, it has an onboard temp sensor(ds18b20 connected to it), and also receives a temperature from another esp8266 via Home assistant.
Some times I lost connection with this device, it can be reached via Esphome, but unreachable via Homeassistant UI.
Could you suggest me a way to disable heating / or use onboard temp sensor(ds18b20 connected to it), if its lost connection to Homeassistant/ to the other esp8266 which serves as a temp sensor to it?
Currently I have a code which checks if the value from the other esp8266 is not null, but obviously its just using old data, so the heating remaining on…
Here is the current code of the device:
dallas:
- pin: D3
update_interval: 60s
- platform: homeassistant
entity_id: sensor.norbiek_temp
- platform: dallas
address: 0x0B0416540EE3FF28
name: "Kazan homerseklet"
#This one used in heating logic
name: "Active Temp sensor"
lambda: |-
if (isnan(id(room_temp).state)){
return id(onboard_temp).state;
} else {
return id(room_temp).state;
text_sensor:
#This one used to display in HA
name: "Active Temp Sensor"
lambda: |-
return {"Kazan homero"};
} else {
return {"Szoba homero"};
switch:
- platform: gpio
pin: D5
on_turn_on:
- lambda: |-
id(gas_thermostat).publish_state();
on_turn_off:
- lambda: |-
binary_sensor:
lambda: |-
return id(example_heater).state;
# Example single-point configuration entry (for heating only)
climate:
- platform: thermostat
name: "Thermostat Climate Controller"
sensor: active_temp
default_target_temperature_low: 20 °C
min_heating_off_time: 30s
min_heating_run_time: 30s
min_idle_time: 3s
heat_action:
- switch.turn_on: example_heater
idle_action:
- switch.turn_off: example_heater
Thank you very much for your help in advance!
