I am using a Scheduler to change the target temperature of the Generic Thermostat at different times of the day/week - I believe this means using the “away_temp” parameter will interrupt the scheduled temperatures, because in theory when I return home the temperature will go to the “target_temp” rather than the previous temperature set by the Scheduler?
So rather than set “away_temp” when away I want to turn the heating off.
I’ve tried to create an automation (is this the right thing to do?) with the below values that I assume should trigger when the house has no one present so “Away”. It doesn’t seem to work - any advice would be welcome!
Or is there a better way to go about this?
In an ideal world there would be an “Away” temperature and a “Home” temperature.
When “Away” the thermostat uses that temp, when “Home” it uses the home temperature which the Scheduler can change accordingly.
- id: '1665944585134'
alias: Thermostat - Away Mode
description: ''
- platform: state
entity_id: group.all_devices
to: not_home
condition: []
- service: climate.set_operation_mode
entity_id: climate.thermostat
operation_mode: 'OFF'
mode: single
