Turn off if device is on for X minutes even after restart
Hi all,
I’m newbie and trying out my hand at automation. Apologies if it has been asked or answered before.
I have a heater connected to smart plug. I have set an automation which turns it off after 45 minutes. It has worked beautifully and in most cases. However, if I restart Home Assistant, it stops working.
Is there way to extend this to continue after reboot? I’m thinking to setup a helper to record the time when smart plug is turned on but not sure how to restart other automation without trigger and also it doubles up automations (I plan to include more such timers for different room).
alias: Matter Plug 2 - Auto Off - 45 Min
description: ""
triggers:
  - trigger: state
    entity_id:
      - switch.matter_plug_2
    to: "on"
    for:
      hours: 0
      minutes: 45
      seconds: 0
conditions: []
actions:
  - action: switch.turn_off
      entity_id:
    data: {}
mode: single
Hey
To overcome this problem, you need to create the automation to start a Timer instead of using the time in the automation. The delay in the automation does not transfer during the reboot.
This is example, when I switch on my backdoor light it will stay on for 10 Minutes then switch off.
alias: Automation - Backdoor - Light - Timer
description: ""
mode: single
triggers:
  - entity_id:
      - switch.back_door_light_switch_1
    to: "on"
    trigger: state
  - event_type: timer.finished
    event_data:
      entity_id: timer.backdoor_light
    trigger: event
conditions: []
actions:
  - choose:
      - conditions:
          - condition: trigger
            id:
              - timer_complete_backdoor_light
        sequence:
            metadata: {}
            data: {}
              device_id: 740c089ef7abebf88c95f4d3c95c1666
      - conditions:
          - condition: state
            state: idle
        sequence:
          - metadata: {}
              duration: "00:10:00"
            action: timer.start
You can create the timer during the automation configuration, but would recommend doing separately: Setting → Devices → Helpers → Create a Helper
The select Timer and give it a name and “tick” the restore box, as that will restore the timer to is state before the reboot / reload.
Thanks @BambamNZ works perfectly. I was worried about timer being finished when HA restarts (or power failure) but seems it is triggered as soon as HA boots up.
I’ve worked little more on the automation and added few more features. I also (tried) created a blueprint to replicate it across rooms & switches.
  • On switch on, start timer is not already running
  • On timer finishing off, turn off the switch
  • If Switch is turned off halfway the timer, cancel timer
  • Allow for multiple queued (in case & not sure it I can test it)
alias: Matter Plug 2 - Auto Off - 45 Min Timer
description: ""
triggers:
  - trigger: state
    entity_id:
    to: "on"
  - trigger: event
    event_data:
      entity_id: timer.matter_plug_2
  - trigger: state
    entity_id:
    to: "off"
conditions: []
actions:
  - choose:
      - conditions:
            id:
              - timer_matter_plug_2_finished
          - condition: state
            entity_id: switch.matter_plug_2
            state: "on"
        sequence:
            metadata: {}
            data: {}
      - conditions:
            id:
              - turned_On
          - condition: state
            state: idle
        sequence:
          - action: timer.start
            metadata: {}
              duration: "00:45:00"
      - conditions:
            id:
              - turned_Off
          - condition: state
            state:
              - active
              - paused
        sequence:
          - action: timer.cancel
            metadata: {}
            data: {}
mode: queued
max: 5
Hi!
I created an integration to fix this issue with some automations/devices. Auto Off Timer(GitHub - 0x3333/auto_off_timer: A Home Assistant custom component that automatically turns off configured lights after a user-defined timeout.)
When a device is turned on, it will start a timer, and when this timer expires, it turn the device off. The timer is persistent, which means that even if you restart HA, when it get back, the timer is restored. If the timer has expired while HA was off, it will trigger the turn off service on the device when HA is restarted, this helps not leaving the device ON forever.
I use it for mirror heaters, some lights that I don’t want to be on forever, bathroom exhaust fan, etc.
Hope it helps.
