I’m speechless… Don’t know what’s wrong in my automation
I want to turn off some light when a door is locked.
My setup is a door lock controlled with Zwave (Danalock brand) and Dimmer controlled via MQTT.
Home assistant can control with no issue everything (lock and unlock, turn on and turn off light).
I’m on hass.io 0.88.0
I did this automation :
- id: '1550785973821'
alias: Turn off light after door locked
- entity_id: lock.polycontrol_danalock_v3_locked_avant
platform: state
to: locked
condition: []
- delay: 0:00:15
- data:
entity: light.vestibule
service: light.turn_off
- data:
entity: light.murale_exterieur_avant
But got the idea to restart completely Home Assistant and bingo, it work… Thank You
Then started Node-RED (was trying it) and it stopped working… than some lights will come on for no reason, one light was part of an automation in Node-RED, so was putting the fault on a bad setting from me, but 3 lights were turning on for no reason, 2 are from the automation of this topic (not in Node-RED), and one other was not part of any automation at all. and the weirdest think is that Home Assistant won’t receive the Mqtt signal that the light is turned on.
Now that I removed Node-RED, 2 of the lights are stopped to misbehave, but the 2 from this automation are still reluctant, but don’t light up as often than with Node-RED.
All dimmer are exactly the same model (there’s more than 30 all over the house), all have Tasmota 6.4.1, all are connected to the same SSID, all have the same GEO, TIME, NST SERVER and POWER Retain 1… In fact I used the Tuya over the air method to flash. Then set one with my parameter, save the config, then upload the config to the others then change the Friendly Name and MQTT topic. All have the same YAML config. and all work well with Home Assistant.
