Turn off light on a timer
I’m brand new to AppDaemon and writing my first app. I’m trying to set a timer on a light when it turns on. That part works, but it sets the timer 2 times when the light turns on. Any ideas?
Here’s the code:
import appdaemon.plugins.hass.hassapi as hass
class LightTimer(hass.Hass):
    def initialize(self):
        try:
            self._entity_id = self.args.get('entity_id', None)
            self._timeout = int(self.args.get('timeout', 0))
        except (TypeError, ValueError):
            self.log("There's a problem with the configuration.", level="ERROR")
            return
        # You must specify an entity
        if self._entity_id is None:
            self.log('The entity is missing.', level="ERROR")
            return
        # Only accepts on and off values for entity_id
        state = self.get_state(self._entity_id)
        if state not in ['off', 'on']:
            self.log("Invalid state: {}. Expecting either on or off.".format(light_state), level="WARNING")
            return
        # if no time is specified, set it to 60 seconds.
        if self._timeout == 0:
            self._timeout = 60
        # Listen for the light to turn on
        if self._entity_id is not None and self._timeout is not None:
            self.listen_state(self.light_turned_on, self._entity_id, new="on")
        # Done
        self.log("Ready to go")
    # When the light turns on, start a timer.
    def light_turned_on(self, entity, attribute, old, new, kwargs):
        self.log('The current state is ' + self.get_state(self._entity_id))
        if self.get_state(self._entity_id) == 'on':
            self.start_timer()
    # Set the entity to turn off after the timeout is reached.
    def start_timer(self):
        self._timer = self.run_in(self.turn_off_light, self._timeout)
        self.log('Timer set for ' + str(self._timeout) + ' seconds.')
    # Turn off the light when the timer expires
    def turn_off_light(self, kwargs):
        self.log('Turning off ' + self._entity_id)
        self._timer = None
        self.turn_off(self._entity_id)
        self.log(self._entity_id + ' turned off.')
Here’s how I’m calling it:
turn_off_office_light:
  module: lighttimer
  class: LightTimer
  entity_id: light.office
  timeout: 60
Here’s the log file:
2019-12-22 14:42:13.336439 INFO AppDaemon: Reloading Module: /config/appdaemon/apps/lighttimer.py
2019-12-22 14:42:13.338480 INFO AppDaemon: Initializing app turn_off_office_light using class LightTimer from module lighttimer
2019-12-22 14:42:13.340246 INFO turn_off_office_light: Ready to go
2019-12-22 14:42:20.561491 INFO turn_off_office_light: The current state is on
2019-12-22 14:42:20.562568 INFO turn_off_office_light: Timer set for 60 seconds.
2019-12-22 14:42:23.347497 INFO turn_off_office_light: The current state is on
2019-12-22 14:42:23.348557 INFO turn_off_office_light: Timer set for 60 seconds.
2019-12-22 14:43:20.003136 INFO turn_off_office_light: Turning off light.office
2019-12-22 14:43:20.019176 INFO turn_off_office_light: light.office turned off.
I was able to get it working by adding old=“off” to the listener.
I tried to add support for passing more than one entity so I can specify multiple switches to turn off at different intervals. Unfortunately, when the light turns on, it immediately turns off. It’s like the delay is being ignored. Any ideas?
        try:
            self._entities = self.args.get('entities', None)
            return
        if self._entities is None:
            self.log('No entity is specified.', level="ERROR")
            return
        for entity in self._entities:
            entity_name = entity["entity"]
            state = self.get_state(entity_name)
                self.log("Invalid state for {}: {}. Expecting either on or off.".format(entity_name, state), level="WARNING")
                continue
            # self._timer = None
            self.listen_state(self.entity_turned_on, entity_name, new="on", old="off")
        # Done
    def entity_turned_on(self, entity, attribute, old, new, kwargs):
        passedEntity = entity
        self.log("The entity was turned on: " + passedEntity)
            if entity_name == passedEntity:
                try:
                    timeout = entity["timeout"]
                except:
                    self.log('No timeout given. 60 seconds will be used by default.', level="WARNING")
                    timeout = 60
                self.log("Setting a timer for " + entity_name + " for " + str(timeout))
                self.start_timer(entity_name, timeout)
    def start_timer(self, entity_name, timeout):
        self.log("Starting a timer for " + str(timeout) + " seconds")
        self.handle = self.run_in(self.turn_off_entity(entity_name), int(timeout))
    def turn_off_entity(self, entity):
        self.log("Turning off light")
        self.turn_off(entity)
        self.handle = None
And in the apps.yaml:
turn_off_lights:
  module: lighttimer
  class: LightTimer
  entities:
    - entity: light.office
      timeout: 10
Hi Brian,
Have you already fixed your problem?
I have solved a similar problem with the “duration” in “listen_state”. But I’m not entirely happy with it either.
            self.listen_state(self.entity_turned_on, entity_name, new="on", old="off", duration = 60)
If you have gone further and found a suitable solution, I would be happy to hear about it.
