Turn off lights with a timer including a lock to stop the light from turning off (Tasmota Multi-tap MQTT Message)
I want some of my lights to switch off after a certain period of time. So I created an automation for it.
However in some cases I may want that light to stay on longer than the time out. e.g. I am in the pantry doing something that will take longer than 5 minutes, but the light goes off every 5 minutes.
As I have Tasmota based touch switches to control the lights, I want to assign a double, triple or quad press of the switch to ‘lock’ it on so it does not turn off after the normal timeout period.
nb: This is setup so the second trigger is specifically for a Tasmotised, multi tap switch with MQTT, but could be changed to use any other trigger:
blueprint:
  name: Timed Light with lock
  description: Define a timed light with a delayed turn off, with the ability to lock the light on using an Tasmotta , TRIPLE or QUAD click
  domain: automation
  input:
    target_light:
      description: The Light
      selector:
        entity:
          domain: light
    delay:
      description: The delay in minutes before switching off the light
      selector:
        number:
          min: 5
          max: 120
          mode: slider
          unit_of_measurement: minutes
          step: 5
    mqtt_message:
      description: The Tasmota multi-tap MQTT Message that will lock the light on (e.g. stat/tasmota_999999/BUTTON1T)
      selector:
        text:
    trigger_type:
      name: the type of Tasmota multi-tap
      description: The type of multi-tap
      selector:
        select:
          options:
            - DOUBLE
            - TRIPLE
            - QUAD
  - platform: state
    entity_id: !input target_light
    to: "on"
  - platform: mqtt
    topic: !input mqtt_message
    value_template: "{{ value_json.TRIG }}"
    payload: !input trigger_type
  - service: automation.turn_off
      entity_id: "{{ this.entity_id }}"
      stop_actions: false
  - service: light.turn_on
  - delay:
      milliseconds: 100
  - service: automation.turn_on
  - condition: trigger
  - delay:
      minutes: !input delay
  - service: light.turn_off
    data: {}
mode: restart
gist is here: timed_light_with_mqtt_lock.yaml · GitHub
