Turn off switch when number less than x
Hi all!
I have a switch to turn a screen up or down and I get a status value of the screen.
I need to have the switch turned off when the status is 0% or 100%.
I’m able to create an automation that turns off the switch when a value is reached.
But when my screen is fully closed, and I turn the close switch on AGAIN, it remains on.
So: if screen is at 0% already and I send the command to close again, the close command should reset itself automatically.
Here are 2 rules I made and they work seperately but I can’t really combine them…
This rule turns of the switch when the status CHANGES TO less than 0.01.
Problem: if switch.mb_con_screenn3_down changes to on when sensor.mb_screenn3_stand is already 0, the switch stays on…
- id: "ScreenN3_Full_Closed1"
  alias: "Screen N3 Full Closed1"
    - platform: numeric_state
      entity_id: sensor.mb_screenn3_stand
      below: 0.01
    - service: switch.turn_off
      entity_id: switch.mb_con_screenn3_down
and:
This rule turns the switch of, when it CHANGES TO on, AND sensor.mb_screenn3_stand is less than 1.
Problem: if sensor.mb_screenn3_stand is 50% and you turn on switch.mb_con_screenn3_down, then switch.mb_con_screenn3_down is not turned off when sensor.mb_screenn3_stand reaches 0.
- id: "ScreenN3_Full_Closed2"
  alias: "Screen N3 Full Closed2"
    platform: state
    to: "on"
  condition:
    condition: numeric_state
    below: 1
So I need a combination of these rules because I have many screens and my code becomes pretty messy and unreadable if I need this double rules for all screens…
Does anyone have an idea to achieve this?
Thanks!
it will trigger as triggers are or and conditions are and. Since below 0.1 is also below 1 it will trigger true and execute.
Thanks! Just tried it and works like a charm!
