Turn off transcoding of video stream from yaml Homekit
Greetings, collected through yaml configuration video doorbell from the button and a separate camera, however, when throwing the camera stream from it is re-encoded creating a loose picture. Is it possible to disable h264 decoding from yaml configuration as my camera already gives stream in h264? This functionality is present when streaming through ui integrations.
Also, when using any of the options, audio when viewing from Homekit on iphone is very intermittent, it works or not
Please do not ccross-post. You asked the same thing here:
this is likely because we have restrictions on first posts, not on purpose.
I accidentally chose the wrong topic, and changing it created a new topic without the ability to delete the old one
Ah, ok. Understandable. The reason I flagged one is to avoid two threads being answered independently, and or make sure people were aware of the other thread in case answers were to be found there. Mods can merge threads or close the duplicate. Regulars can help you change the categories, so just ask next time and we’ll fix it for you.
Hopefully you’ll get your answer soon!
Thanks) I’ll keep you in mind
I also saw it on Discord.
(But who’s counting…)
I’m not looking at other platforms.
