Turn on a switch by a binary_sensor on the ESP device
Hi
I would trigger the buzzer connected at GPIO17 when i detect water in my basement. Now i´m sending the sate to HA and trig the buzzer by automation , but it would be better for me to have this internal in the ESP device, then the alarm will go off even if the HA server is down of some reason.
If possible i would like the buzzer not just turn on , but shifting from on to off in a cycle to give a pulsing sound,
  - platform: adc
    pin: GPIO32
    attenuation: 11db #adjust the input voltage range from 1 volt to 3 volt
    update_interval: 10s
# Example configuration entry
binary_sensor:
    lambda: |-
      if (id(hp_room_water_level).state > 2.00) {
        // basement is ok.
        return false;
        #set GPIO17 low
      } else {
        // basement is flooded.
        return true;
        #set GPIO17 high
switch:
  - platform: gpio
    pin: GPIO17
sensor used to detect water:
Something like (untested):
binary_sensor:
    lambda: |-
        // basement is ok.
        return false;
        #set GPIO17 low
      } else {
        return true;
        #set GPIO17 high
    on_press:
      then:
        - output.turn_on: buzzer_one
    on_release:
      then:
        - output.turn_off: buzzer_one
switch:
  - platform: slow_pwm
    pin: GPIO17
    period: 1s
Hi and thanks for your input.
small modification’s switch: has been changed to output: to be able handle the slow_pwm.
Now the busser are trigged by the internal code on the ESP, that is exact what i was looking for.
also the -output.set_level was added to get the pulsing sound , other vise the signal was on the whole time.
    - platform: adc
    pin: GPIO32
    attenuation: 11db
binary_sensor:
      lambda: |-
          // basement is ok.
          return false;
        } else {
          return true;
      on_press:
        then:
          - output.set_level:
             level: 50%
      on_release:
        then:
output:
    pin: GPIO17
    period: 1s
