Turn on a switch when motion is detected
I changed the default motion sensor blueprint to match any switch!
Turn on switch when motion is detected. Leave it on for X seconds after motion is detected.
Edit 2020-12-17: Added time conditions, hope it works.
Get started
Click the badge to import this Blueprint: (needs Home Assistant Core 2021.3 or higher)
blueprint:
  description: Turn on a switch when motion is detected.
  domain: automation
  input:
    motion_entity:
      selector:
        entity:
          domain: binary_sensor
          device_class: motion
    lightsensor_entity:
      selector:
        entity:
          domain: sensor
          device_class: illuminance
    illuminace_level:
      name: Max Illuminance
      description: Maximal immuminance level in lux. If illuminance is higher, light
        will not be enabled
      default: 300
      selector:
        number:
          min: 0.0
          max: 5000.0
          unit_of_measurement: lux
          mode: slider
          step: 1.0
    switch_target:
      selector:
          entity:
            domain: switch
    time_from:
      description: A time input which defines the time from which motion is detected
      selector:
        time: {}
    time_to:
      description: A time input which defines the time to which motion is detected
      selector:
        time: {}
    no_motion_wait:
      description: Time to leave the light on after last motion is detected.
      default: 120
      selector:
        number:
          min: 0
          max: 3600
          unit_of_measurement: seconds
mode: restart
max_exceeded: silent
- platform: state
  entity_id: !input 'motion_entity'
  to: "on"
condition:
- condition: and
  conditions:
    - condition: time
      after: !input 'time_from'
      before: !input 'time_to'
    - condition: numeric_state
      entity_id: !input 'lightsensor_entity'
      below: !input 'illuminace_level'
- service: switch.turn_on
  target: !input 'switch_target'
- wait_for_trigger:
    platform: state
    to: "off"
- delay: !input 'no_motion_wait'
- service: switch.turn_off
Just curious what kind of switches you’re using this blueprint for?
I can’t speak for OP, but I have light switches throughout my house that only show up as switches in HA.
You can use the light.switch component to make them into light entities in that case.
I was not aware of that component, thank you very much!
I wanted to use it for all my 30+ wifi tuya switches that don’t show up as “light”.
I was not aware of the “light.switch component”, but now you can use both :wink:
Thanks. maybe add a sun Condition
Yes that’s a great idea
Perhaps consider adding a time condition, so the trigger only happens during specific hours of the day?
i.e. If I use this for light switches, I don’t want this executing during “daylight”, so I might want to limit to “dark” hours or between sunset/sunrise etc.
I have like 20 switches and if I used that I would have a lot of duplicate entities.
I created a config with that, but also struggle with the missing condition feature like sun state or time. Even the room has enough light, it always triggers the lights. I also use tuya wifi switches and can’t use them here, only my lightify via services or Philips via device config are selectable. I have some lights controlled with power plugs, they also won’t appear to select.
Would be cool if you could extend it to define/use dependencies and more devices like power plugs and wall switches.
Did someone manage to have this with conditions?
I don’t believe more features will be added. It’s just an exact copy of the original, but it uses switch instead of light. Try asking in #configuration:blueprints and see if anyone will help you.
I’m the first to admit that I’m not a programmer, I try to learn but don’t have much time to spare.
I tried with this, tell me if it don’t work!
blueprint:
  domain: automation
  input:
    motion_entity:
      selector:
        entity:
    lightsensor_entity:
      selector:
        entity:
          domain: sensor
    illuminace_level:
        will not be enabled
      default: 300
      selector:
        number:
          min: 0.0
          max: 5000.0
          mode: slider
          step: 1.0
    switch_target:
      selector:
          entity:
            domain: switch
    time_from:
      selector:
        time: {}
    time_to:
      selector:
        time: {}
    no_motion_wait:
      default: 120
      selector:
        number:
          min: 0
          max: 3600
mode: restart
- platform: state
  to: "on"
condition:
- condition: and
  conditions:
    - condition: time
- wait_for_trigger:
    platform: state
    to: "off"
Thanks, I’m going to try it
Oh man… Perfecto!:wink:
Was working but am getting an error with latest version of HA system
unknown tag !<!input> at line 62, column 36:
entity_id: !input ‘motion_entity’
Any ideas?
You’re trying to add the blueprint as an automation.
Not yet. I just imported the blueprint and went to the file editor and opened this blueprint and the error shows up instantly. Have not created the automation yet.
