Hi all,
I am new to Home Assistant and this forum.
I am trying to create an automation that does the following:
When the illuminance (lux) of a sensor is below 20 lux for 2 minutes
and the time is between 16 and 22 hour
2 scenes are started
The automation is only working when the illuminance does not drop before 16h. When the illuminance drops below 20 before 16h I can see in the trace log that it does not trigger because the time is not met. However it stops checking after this… It never checks again.
Is there a possibility to keep on checking until both are met?
I have tried some blueprints, I have tried with the repeat action, I have tried moving the trigger and conditions around but so far nothing seems to work, Can someone help?
My initial automation is as following:
alias: "Woonkamer & Bar - Verlichting Aan: Sensor"
description: ""
- platform: numeric_state
entity_id: sensor.sensor_woonkamer_illuminance
for:
hours: 0
minutes: 2
seconds: 0
below: 20
condition:
- condition: and
conditions:
- condition: time
before: "22:00:00"
after: "16:00:00"
- service: scene.turn_on
entity_id: scene.bar_gedimd
metadata: {}
entity_id: scene.woonkamer_spots_ontspannen
metadata: {}
mode: single
