Marcoach
(Marco)
April 19, 2021, 3:12pm
1
Hi all
Thanks in advance !
What I need is to have an Automation that , based on a sensor state (On / off ) turns on and off the light ( and this is simple ) but in the meantime i need to set the brightness to a certain percentage …
the only automation to turn on and off works perfectly :
Accendi Balcone (on+off) (Duplicate)
description: ''
- platform: state
entity_id: binary_sensor.balcone_sensore_motion
condition:
- condition: state
entity_id: binary_sensor.notte
state: 'off'
- service: |
{% if trigger.to_state.state == "on" %}
light.turn_on
{% else %}
light.turn_off
{% endif %}
entity_id: light.balcone
mode: single
but if i set also the brightness the turn off part does not works :
alias: Accendi Balcone (on+off) (Duplicate)
description: ''
- platform: state
condition:
- condition: state
state: 'off'
- data:
brightness_pct: 50
service: |
light.turn_on
{% else %}
light.turn_off
{% endif %}
mode: single
Of course the problem is that I cannot set brightness while i’m turning off but is there a way to do that instead of using 2 automation ( one to turn on and one to off ) ?
many thanks .
I think you should be able to do this with a choose/condition under action rather than via a service call.
The following is an example of an action from my config but unfortunately I don’t have one that changes the brightness:
- choose:
- conditions:
- condition: template
value_template: '{{ trigger.event.data.command in [''left_single''] }}'
sequence:
- device_id: 5320c28c7c1e45c580aa9a5ad9bc4432
domain: light
entity_id: light.kitchen_lights
type: toggle
- conditions:
value_template: '{{ trigger.event.data.command in [''right_single''] }}'
sequence:
- service: light.toggle
data: {}
entity_id: light.lounge_lamps
Marcoach
(Marco)
April 19, 2021, 3:34pm
3
thanks Jonah1970,
I will try in the next days
thanks.
I finally solved my problem using 2 scripts: one to turn on and one to turn off.
for who is interestested following the code I used.
in my script.yaml file :
To turn lights on with brightness percentage :
alias: Light On Dim
sequence:
- service: light.turn_on
entity_id: '{{ entita }}'
data_template:
brightness_pct: '{{ luminosita_pct }}'
mode: single
to turn off lights:
alias: Light off Dim
sequence:
- service: light.turn_off
mode: single
and the automation :
description: ''
- platform: state
condition:
- condition: state
state: 'on'
- service_template: |
script.light_on_dim
{% else %}
script.light_off_dim
{% endif %}
data_template:
entita: light.balcone
luminosita_pct: >
{% if is_state('input_boolean.luci_bassa_intensita', 'on')
20
{% else %}
100
{% endif %}
mode: single
as you can see I also set the brightness depending on a sensor state.
Thanks for the help.
Marco A.
