Hi, please, please help. I am trying to turn on my boiler when the temperature in a room is below the set temperature. I’ve got the following code, which seems to make sense to me, but its giving an error in config. I’m at a loss. If it helps I’m using the Max Cube turned in to a CUN.
Thank you for your help. Did you just mean the word template like below? Still saying config error - all my other automations are working and I’m using same indentation.
Thank you both, thats brilliant advice… I’ve found out my Zwave extender dies which meant the boiler wasnt connected to the network - so it was triggering, just not turning it on. Waiting for a new extender and will try then.
