Do I have the logic here right? I want the ceiling fan to turn on only if both phones are being charged, and then turn off only if both phones are not being charged.
"id": "1c43178ce79561f9",
"type": "tab",
"label": "Test Flows",
"disabled": false,
"info": "",
"env": []
"id": "142960ea6b0cd901",
"type": "server-state-changed",
"z": "1c43178ce79561f9",
"name": "Samsung Charging",
"server": "4e3730d1.5341d",
"version": 4,
"exposeToHomeAssistant": false,
"haConfig": [
"property": "name",
"value": ""
"property": "icon",
"value": ""
"entityidfilter": "sensor.sm_s906u_battery_state",
"entityidfiltertype": "exact",
"outputinitially": false,
"state_type": "str",
"haltifstate": "charging",
"halt_if_type": "str",
"halt_if_compare": "is",
"outputs": 2,
"output_only_on_state_change": true,
"for": "0",
"forType": "num",
"forUnits": "minutes",
"ignorePrevStateNull": false,
"ignorePrevStateUnknown": false,
"ignorePrevStateUnavailable": false,
"ignoreCurrentStateUnknown": false,
"ignoreCurrentStateUnavailable": false,
"outputProperties": [
"property": "payload",
"propertyType": "msg",
"value": "",
"valueType": "entityState"
"property": "data",
"value": "",
"valueType": "eventData"
"property": "topic",
"value": "",
"valueType": "triggerId"
"x": 190,
"y": 160,
"wires": [
"f54d211f8c307c1d"
"cf10b2b8285b9c29"
"id": "cf10b2b8285b9c29",
"type": "api-call-service",
"name": "",
"version": 5,
"debugenabled": false,
"domain": "fan",
"service": "turn_off",
"areaId": [],
"deviceId": [
"7bd734ad91a848408f4105ba0c31012d"
"entityId": [
"switch.fan_controller"
"data": "",
"dataType": "jsonata",
"mergeContext": "",
"mustacheAltTags": false,
"outputProperties": [],
"queue": "none",
"x": 750,
"y": 300,
"wires": [
"id": "023369e359e027a9",
"name": "",
"version": 5,
"domain": "fan",
"service": "turn_on",
"areaId": [],
"deviceId": [
"entityId": [
"data": "",
"mergeContext": "",
"queue": "none",
"x": 750,
"y": 220,
"wires": [
"id": "d149619704489160",
"name": "Iphone Charging",
"version": 4,
"haConfig": [
"property": "name",
"value": ""
"property": "icon",
"value": ""
"entityidfilter": "sensor.iphone_battery_state",
"outputs": 2,
"for": "0",
"forType": "num",
"value": "",
"property": "data",
"value": "",
"value": "",
"x": 180,
"y": 320,
"wires": [
"950ae9404f64280b"
"cf10b2b8285b9c29"
"id": "f54d211f8c307c1d",
"type": "api-current-state",
"name": "Iphone Battery State",
"version": 3,
"outputs": 2,
"halt_if": "charging",
"entity_id": "sensor.iphone_battery_state",
"blockInputOverrides": false,
"value": "",
"property": "data",
"value": "",
"valueType": "entity"
"for": "0",
"forType": "num",
"override_topic": false,
"state_location": "payload",
"override_payload": "msg",
"entity_location": "data",
"override_data": "msg",
"x": 440,
"y": 160,
"wires": [
"023369e359e027a9"
"cf10b2b8285b9c29"
"id": "950ae9404f64280b",
"name": "Samsung Battery State",
"version": 3,
"outputs": 2,
"entity_id": "sensor.sm_s906u_battery_state",
"value": "",
"property": "data",
"value": "",
"for": "0",
"forType": "num",
"x": 390,
"y": 260,
"wires": [
"023369e359e027a9"
"cf10b2b8285b9c29"
"id": "4e3730d1.5341d",
"type": "server",
"name": "Home Assistant",
"addon": true,
"rejectUnauthorizedCerts": true,
"ha_boolean": "",
"connectionDelay": false,
"cacheJson": false,
"heartbeat": false,
"heartbeatInterval": "",
"statusSeparator": "",
"enableGlobalContextStore": false
