I want to read sensor states from home assistant (binary sensors or switches) and show their status (on/off) via LEDs connected to a ESP8266 Board.
Basically it is working except that initially after booting the ESP, the current state of the sensors are not published to the LEDs because of the “on_state”-Trigger which only triggers on a new state.
Here is my config:
output:
# LED at GPIO15
- platform: gpio
pin: GPIO15
binary_sensor:
- platform: homeassistant
entity_id: binary_sensor.brennerstatus
internal: true
on_state:
then:
- if:
condition:
binary_sensor.is_on: brennerstatus
then:
- logger.log: "ON"
- output.turn_on: brennerled
#- delay: 1s
else:
- logger.log: "OFF"
- output.turn_off: brennerled
So when the state is changing the LEDs turn on or off. But when the initial state is on and the ESP boots, the LED stays off until the next “off” and “on” state. Is there a possibility that the automation is always checked, and not only on some trigger events? Or are there alternative ways to implement this feature?
Regards
Michael
