Terp
August 26, 2019, 6:15pm
1
Hi guys.
Im starting to lose my hair over this.
I have a hue color bulb, and what i want is:
If the bulb is off, and i turn it on, it should be the normal white-yellow-ish light
If the bulb is allready on, and i hit the “turn on” button on my remote, it should go to the next color on the color wheel, and if i click and again, next color and so on.
The last part if have figured out, but not the first one.
This is what i go:
- alias: CycleColor
initial_state: true
platform: event
event_type: deconz_event
event_data:
event: 1002
- service: light.turn_on
entity_id:
- light.hue_bulb
data_template: >-
{%- if is_state('light.hue_bulb', 'on') -%}
hs_color:
- "{{ (30 + (state_attr('light.hue_bulb', 'hs_color')[0] or 0)) % 360 }}"
- 100
brightness_pct: 100
{%- else -%}
xy_color: [0.4497,0.408]
color_temp: 330
brightness: 254
{%- endif -%}
transition: 1
And the error i get:
2019-08-26 18:08:58 ERROR (MainThread) [homeassistant.config] Invalid config for [automation]: expected a dictionary for dictionary value @ data[‘action’][0][‘data_template’]. Got ‘{% if is_state('light.hue_bulb', 'on') %}\n hs_color:\n - “{{ (30 + (state_attr('light.hue_bulb', 'hs_color')[0] or 0)) % 360 }}”\n - 100\nbrightness_pct: 100 {% else %}\n xy_color: [0.4497,0.408]\n color_temp: 330\n brightness: 254\n{% endif %} transition: 1\n’. (See /config/automations.yaml, line 136). Please check the docs at Automation - Home Assistant
The xy color i got from just setting the color in HA and just seeing the event in the logs
A template cannot span multiple parameters. You need to use an individual template in each parameter.
Terp
August 26, 2019, 6:52pm
3
Thanks for your quick response.
I have changed it up to something a bit more simple
data_template:
hs_color: >
- {% if is_state('light.hue_bulb', 'on') %} {{ (30 + (state_attr('light.hue_bulb', 'hs_color')[0] or 0)) % 360 }} {% else %} 255 {% endif %}
- 100
brightness_pct: 100
transition: 1
But that gives me:
Invalid data for call_service at pos 1: None for dictionary value @ data[‘hs_color’]
Also, by " You need to use an individual template in each parameter."
Do you mean it like i did? for each of my - i need an if?
Yes, that is better. I think the current issue with that snippet is you’re missing quotes. Try:
data_template:
hs_color: >
- "{% if is_state('light.hue_bulb', 'on') %} {{ (30 + (state_attr('light.hue_bulb', 'hs_color')[0] or 0)) % 360 }} {% else %} 255 {% endif %}"
- 100
brightness_pct: 100
transition: 1
And, yes, if you’re trying to calculate values for an array/list, you need to use a separate template for each value of the array/list. Which, BTW, would not be the case if my PR was accepted, but it has been ignored.
Terp
August 26, 2019, 7:01pm
5
Yea that would make sense, just hate doing the same if’s over and over again if i need to change multiple things on the same “block”
But the quotes around it didnt help, same error
Can you post the entire automation as it exist now (that is causing the error, and the error if it’s changed)?
Terp
August 26, 2019, 7:04pm
7
Oh figured it out, had to remove the > from “hs_color: >”
Duh. Yes, should have noticed that. Good catch!
Terp
August 26, 2019, 7:07pm
9
Just a question from pure curiosity, this seems to work fine for me.
But what if i wanted to do as i first described.
only do hs_color if on, if not on then do xy_color?
That, unfortunately, is a bit problematic. HA’s script component is very basic. Probably the easiest way is to do the work in two different scripts, then use a service_template
to call one or the other based on whether or not the light is currently on. Or maybe implement in a python_script
Terp
August 26, 2019, 7:26pm
11
Okay, i was afraid, you would say that
Thanks alot for your help!
timinski
(Timinski)
August 27, 2019, 12:59pm
12
Just wanted to second that thank you to pnbruckner. Kudos on such terrific, patient help on Terp’s issue. Well done.
