I have a zigbee dimmer which I controll via HA. The dimmer can be turned on and off in the UI but the device itself remembers the brightness of the dimmer.
So for now I have created an automation that after the light is turned on the brightness will set to 255. The problem is that there is some blinking, because it is turned on at a low bightness and after a second it fades to 255.
So is there a way to tell the light.turn on (especially for this device) to switch on with the brightness 255?
I thought about something like overriding the turn_on entry in the customize.yaml like:
light.dimmer_livingroom:
turn_on:
brightness: 255
Is this possible?
