Turn on lights with first motion in morning
I’m a fiddler, not a programmer and as such, I’ve benefited greatly from all of the bits of code that users have posted in the forums. Thanks! Here’s my contribution.
What it does: When I first come downstairs, a motion sensor in my livingroom senses me and turns on some lights. Kind of a “welcome to the day” automation.
This includes: creating and changing the value of an input_boolean, reacting to time and to sunrise, using conditions for an action, using value_templates for conditions, exiting an automation by using a conditon inside the action
input_boolean:
  trigger_first_morning:
    name: Waiting for first morning motion
    icon: mdi:kettle
## These first two control t input_boolean that allows the "first morning action" to occur
## If the action is triggered, it will also disable this boolean. This assumes you have the sun platform enabled.
automation:
#turns it on at 5am
  - alias: Enable First Morning Trigger
      - platform: time
        after: '5:00'
      service: homeassistant.turn_on
      entity_id: input_boolean.trigger_first_morning
# turns it off an hour after sunrise
  - alias: Disable First Morning Trigger
      - platform: sun
        event: sunrise
        offset: "01:00:00"
      service: homeassistant.turn_off
# This is the main automation. It triggers when my motion sensor is triggered
# (in this case, a motion sensor from a security system attached to my Vera)
  - alias: First Morning Motion
      platform: state
      entity_id: binary_sensor.livingroom_motion
      to: 'on'
    # only complete the automation if we're still waiting for the first motion
    condition:
        condition: state
        state: 'on'
      # turn off the "waiting" boolean regardless of whether lights will turn on
      # so that this happens only once
      - service: homeassistant.turn_off
      # But only turn on lights if the living room and kitchen lights are off or dimmed
      # If a condition tests false, the automation will end
      - condition: and
        conditions:
          - condition: numeric_state
            entity_id: light.livingroom_ec
            # if light is off, force a 0, otherwise use the brightness value
            value_template: '{% if states.light.livingroom_ec.state == "on"  %}{{ states.light.livingroom_ec.attributes.brightness }}{% else %}0{% endif %}'
            # brightness below 50% (255 = 100%)
            below: 127
            entity_id: light.kitchen_bar
            value_template: '{% if states.light.kitchen_bar.state == "on"  %}{{ states.light.kitchen_bar.attributes.brightness }}{% else %}0{% endif %}'
            below: 127
            entity_id: light.kitchen_ceiling
            value_template: '{% if states.light.kitchen_ceiling.state == "on"  %}{{ states.light.kitchen_ceiling.attributes.brightness }}{% else %}0{% endif %}'
            below: 127
      # Trigger a scene
      # You could add as many services or scenes as you'd like
      - service: scene.turn_on
        entity_id: scene.morning_first_motion
# here's the scene that gets called. Lights in
# my living room and kitchen turn on.
scene:
  - name: Morning First Motion
    entities:
      light.kitchen_ceiling:
        state: on
        brightness: 127
      light.kitchen_bar:
        state: on
        brightness: 178
      light.kitchen_above_cabinet:
        state: on
        brightness: 178
      light.livingroom_ec:
        state: on
        brightness: 153
      light.livingroom_track:
        state: on
        brightness: 153
This is a great starting project for most and a good example. You really should consider adding it to the cookbook.
I agree!
We need more examples of this magnitude to help instruct new users on how you can use the different parts of the system.
I myself is quite new to HASS and I have been frustrated on multiple occasions due to the lack of good examples. This is of course the usual behaviour with open source and I would like to give my kudos to the developers for producing such a potent system.
Hopefully I can bring my own examples to help newcomers in the future
/R
Thanks. My Git skills are too rusty to figure that out.
Thank you for sharing this @ih8gates - I’ve been trying to work out how to turn my coffee thingo on when I first get up but not keep turning it on. Didn’t even occur to me to use an input boolean.
Same here. There seems to be no “simple” examples. I’m missing something in understanding this. I read one post where the guy was a programmer but couldn’t get his head wrapped around this. I’m similar. I do a lot of Programmable Logic Control and SCADA stuff. Even some of our older stuff was similar to this “type it out” over graphic programming. But there doesn’t seem to be a cheat sheet for the available HA commands. Every day I learn something new but still struggle with the syntax. Was going to post and ask for a simple On/Off four light example. I have 4 Cree bulbs which are seen by the Wink App and also have been discovered by the HA. I can turn them On and Off with HA. But when I try to program something I usually get an error and it doesn’t allow HA to start. So I go back into configuration, remove it, save it. restart HA, and it comes back. Hey I did at least get the Wink API programmed and that works…yeah…
Even if you don’t want to dive into Git, you could always do a gist. Super easy to add to the Cookbook.
OK. How do I add it to the cookbook?
I thought you could use the gist. they changed the format. :frowning: I created a stub file for you in the cookbook though with most of the stuff. Check out the pull request and edit/adjust as necessary.
https://github.com/home-assistant/home-assistant.github.io/pull/1428/files
Carlo
