Turn on/off lights with iOS stair ascent and descent counter
I am trying to turn on additional lights when going upstairs to a bonus room and then turn off when coming back downstairs by using my iOS stair counter. I found some similar topics and have attempted the following with no success. The stair counter works correctly and is reflected in HA but I can’t get the increment to trigger an action
I created a binary sensor:
binary_sensor:
  - platform: trend
    sensors:
      floor_ascended:
        entity_id: sensor.iphone_floors_ascended
Then I created a automation:
alias: Floor ascended Don
description: ""
  - platform: state
  - condition: template
    value_template: "{{ trigger.from_state.state | int < trigger.to_state.state | int }}"
  - service: notify.mobile_iphone
      message: Ascended home floor
  - type: turn_on
    device_id: 569b7e95b343a4064521cdcd04629e3b
    entity_id: switch.lamp_desk
    domain: switch
mode: single
Any advice on how to accomplish this?
You may want to check the traces in the automation to see how far it gets, to make sure your condition works ok (if not, I would change the trigger to be from off to on instead - then no condition needed.
Other thing I noticed, for the last part, I think you need to call a service to turn on the switch…
service: switch.turn_on
data: {}
Thanks. It’s not triggering at all. The light turns on and I get notified when I run it manually, so hopefully it will turn on when it triggers. If not, I can fix that. The trigger is the apparent issue. Unfortunately adding From off To on didn’t cause it to trigger.
Only thing I can think of is that you have your trigger as binary sensor and mine is input_boolean, so off/on may not be valid in your case. You can check the sensor history to see what the states are when it changes, then use those as trigger from-to. Just an idea. :slight_smile:
Your condition is in the trigger block. It should be in the condition block. So not this:
  - platform: state
This:
  - platform: state
condition:
I updated the code to below but still no trigger. Previously, I was attempting to get the trigger signal from the iPhone sensor but here I’m using the binary sensor I created but neither seem to cause a trigger.
alias: Floor Ascend
description: ""
  - platform: state
    entity_id:
      - binary_sensor.floor_ascended
    to: "on"
condition:
Your trigger is a binary sensor (on/off) but you are trying to compare numeric values from the trigger in the condition. That’s not going to work. Delete the trend sensor and try this:
alias: Floor Ascend
description: ""
  - platform: state
    to: # null to: triggers on all state changes, ignores attribute changes
condition:
    value_template: "{{ trigger.from_state.state | int(1) < trigger.to_state.state | int(0) }}"
Awesome! That did it. I’ve used the iPhone sensor in other attempts but didn’t have something just right. Your example works flawlessly.
