c0ntax
(Martin)
October 3, 2020, 3:36pm
1
Can anyone please tell me what I need to add to the below automation to only run the script if the lights are already off.
Automation:
- alias: Sunset Living Room
platform: sun
event: sunset
offset: '-00:30:00'
- service: script.sunset_living_room
Or do I need to add something to the script instead?
Script:
sunset_living_room:
alias: Living Room Sunset
sequence:
- service: light.turn_on
entity_id:
- light.play_bar_1
- light.play_bar_2
- light.play_bar_3
brightness: 80
rgb_color:
- 245
- 107
- 22
entity_id:
- light.tv_l
- light.tv_r
brightness: 12
rgb_color:
- 245
- 81
- 22
- service: light.turn_off
entity_id: light.lounge_light
brg468
(Brian)
October 3, 2020, 3:43pm
2
This should only run if all the lights are off.
platform: sun
event: sunset
offset: '-00:30:00'
condition:
- condition: state
entity_id:
- light.play_bar_1
- light.play_bar_2
- light.play_bar_3
- light.tv_l
- light.tv_r
state: 'off'
- service: script.turn_on
entity_id: script.sunset_living_room
Edit: I think your action needs to be changed as well.
c0ntax
(Martin)
October 3, 2020, 3:51pm
3
Ok, I’ll try that, thanks Brian.
Regarding the action
, I previously had all of them in the same format as you’ve suggested but someone mentioned in another thread that it can be simplified as in the way I have it currently. And it works, so less lines of code required.
brg468
(Brian)
October 3, 2020, 3:52pm
4
Interesting, I’ve never tried it or seen it documented that way, but hey, if it works why not.
tom_l
October 3, 2020, 4:00pm
5
There are differences in what happens when you run a script either of those two ways.
(Taras)
October 3, 2020, 4:05pm
6
If you create the following Light Groups :
light:
- platform: group
entities:
- light.play_bar_1
- light.play_bar_2
- light.play_bar_3
- platform: group
entities:
- light.tv_l
- light.tv_r
- platform: group
entities:
- light.play_bar
- light.tv
then your script can be simplified like this:
sunset_living_room:
sequence:
entity_id: light.play_bar
brightness: 80
rgb_color:
- 245
- 107
- 22
entity_id: light.tv
brightness: 12
rgb_color:
- 245
- 81
- 22
and your automation’s condition can simply be this (assuming you are using 0.115):
platform: sun
event: sunset
offset: '-00:30:00'
condition: "{{ is_state('light.tv_play_bar', 'off') }}"
c0ntax
(Martin)
October 3, 2020, 4:19pm
7
Okay, that’s interesting. I’ll have to have a read of that later for definite. Thanks Tom.
c0ntax
(Martin)
October 3, 2020, 4:22pm
8
I’m yet to decide about how I want to group all my lights and other entities but that’s a good start so thank you.
123
(Taras)
October 3, 2020, 4:29pm
9
Be advised that what I suggested uses the Light Group integration, not the Group integration . The Light Group integration effectively creates a virtual light that supports requests to change brightness, color, etc. The Group integration simply supports turning lights on/off (but supports other things like switches, locks, sensors, etc). Keep this distinction in mind when you begin to organize your lights.
c0ntax
(Martin)
October 3, 2020, 4:38pm
10
I will remember, thanks for the advice.
