I have tautuilli setup and working great so far, but wondering if it’s possible to split up the 1 and only sensor.tautiulli thats in my states tab, i like that i can watch if there’s someone connected and watching my plex server, but would it be possible to split it up so i have another sensor display total bandwidth or any of other monitored conditions?
I have created template sensors with the information I needed and then show them as individual in the frontend.
Check this code and let me know if you it’s what you needed or any help:
sensors:
tautulli_count_transcode:
friendly_name: 'Transcode Count'
value_template: '{{ states.sensor.tautulli.attributes["count_transcode"] }}'
tautulli_direct_plays:
friendly_name: 'Direct Plays'
value_template: '{{ states.sensor.tautulli.attributes["direct_plays"] }}'
tautulli_direct_streams:
friendly_name: 'Direct Streams'
value_template: '{{ states.sensor.tautulli.attributes["direct_streams"] }}'
tautulli_wan_bandwidth:
friendly_name: 'Wan Banddiwth'
value_template: '{{ states.sensor.tautulli.attributes["wan_bandwidth"] }}'
unit_of_measurement: "Mbps"
tautulli_lan_bandwidth:
friendly_name: 'Lan Banddiwth'
value_template: '{{ states.sensor.tautulli.attributes["lan_bandwidth"] }}'
tautulli_total_bandwidth:
friendly_name: 'Total Banddiwth'
value_template: '{{ states.sensor.tautulli.attributes["total_bandwidth"] }}'
neat, where do you put this? sensor.yaml?
yup, check here: https://www.home-assistant.io/components/sensor.template/
wow, thanks giving it a try! I hope you didn’t do all that work just for me!
id give you gold if this were reddit! Perfect
