why does this not work ? I want the volume turn up up up when i hold the button down
it only turn the volume up once.
alias: test knap volume
description: ""
- device_id: 52b5d39251f373fd62616819ec5466bf
domain: deconz
platform: device
type: remote_button_long_press
subtype: button_4
condition: []
- service: media_player.volume_set
volume_level: "{{ state_attr('media_player.kokken', 'volume_level') + 0.1 }}"
entity_id: media_player.kokken
mode: restart
tom_l
February 19, 2023, 5:43pm
2
The automation triggers when it detects a long press and calls the volume up service once. It does not continue to trigger while you are holding the button.
ok, thanks
is it possible to make it?
tom_l
February 20, 2023, 12:13am
4
Only if your button has a release event or state.
Then you can repeat the actions in a loop until a release event occurs. You will need a delay in the loop of actions as home assistant can repeat them extremely quickly. It is also wise to include a default repeat length just in case the release is missed for some reason.
https://www.home-assistant.io/docs/scripts/#repeat-a-group-of-actions
cant get it to work :-/
My button has this
domain: deconz
platform: device
type: remote_button_long_release
subtype: button_4
I cant pick the option button_4_long press
repeat:
until:
condition: device
domain: ""
entity_id: ""
sequence:
- delay:
hours: 0
minutes: 0
seconds: 0
milliseconds: 200
enabled: true
lai95588
(Lai95588)
April 17, 2023, 9:18am
6
Hello, I want to turn up the volume when I press and hold the button, is it solved?
No, I did not get it to work
tom_l
April 17, 2023, 9:30am
8
Dashboard buttons do not.
