Turned the Home assistant logo into a case
Thought some of you may find this cool and was not quite sure where it would go on the forum. I decided to make a case for the Pi and thought why not make the home assistant logo a case
Couple of bits i like about it
-The Zigbee aerial lines up with the chimney
-The space below the Pi is perfectly for a 2.5inch SSD
This is V1, Made a mistake with this design however, the Pi is supposed to slide down some pins BUT as i am using the RGB tower cooler with the Pi it cant slide onto the pins so I need to change that mounting and get a short USB extension cable to connect the Zigbee dongle to the Pi
Superb! I love that especially the RGB cooler shining through. Great idea
