Turning a raspberry pi zero into a network cam for home assistant
I have a Pi zero camera edition, and would like to make it a camera for home assistant.
Was thinking about adding a PIR motion sensor to it as well.
Is this possible, and what is the best way to go about this?
It should work, these links can get you started.
https://www.raspberrypi.org/documentation/configuration/camera.md
Thanks for the info!
About to flash all my raspberry pis.
Going to look into having multiple home assistant nodes and see how that goes.
Sounds like fun!! Good Luck!
I have this setup now but without motion sensor …I have raspbian on the zero and I use Motioneye application for connecting all my webcams then display them in my HASS server config
Hi there!
You could use ‘motion’ to add motion detection http://www.lavrsen.dk/foswiki/bin/view/Motion/WebHome
This might help you access the camera remotely. http://docs.dataplicity.com/docs/stream-live-video-from-your-pi
Best,
Elliot.
(Founder: dataplicity.com)
