I am trying to set my GE 12730 Fan Control Switch to have the LED off when in operation… I am ashamed to admit its taken me hours to get this far and a hell of a lot of reading threads (man documentation is rough… lol). It has three options:
LED ON when light off
LED ON when light on
LED always off
I can switch between the first two settings. However, if I select off, it selects the option and immediately reverts to the previous setting. Its like it can’t apply it. Doesn’t make sense to me when the other two work. Below is what was in the logs. Any ideas?
2017-04-22 18:56:52.748 Info, Node004, Value::Set - COMMAND_CLASS_CONFIGURATION - LED Light - 3 - 1 - LED always off
2017-04-22 18:56:52.749 Info, Node004, Configuration::Set - Parameter=3, Value=2 Size=1
2017-04-22 18:56:52.750 Detail, Node004, Queuing (Send) ConfigurationCmd_Set (Node=4): 0x01, 0x0c, 0x00, 0x13, 0x04, 0x05, 0x70, 0x04, 0x03, 0x01, 0x02, 0x25, 0x45, 0xf5
2017-04-22 18:56:52.751 Detail, Node004, Queuing (Send) ConfigurationCmd_Get (Node=4): 0x01, 0x0a, 0x00, 0x13, 0x04, 0x03, 0x70, 0x05, 0x03, 0x25, 0x46, 0xf4
2017-04-22 18:56:52.752 Info, Node004, Sending (Send) message (Callback ID=0x45, Expected Reply=0x13) - ConfigurationCmd_Set (Node=4): 0x01, 0x0c, 0x00, 0x13, 0x04, 0x05, 0x70, 0x04, 0x03, 0x01, 0x02, 0x25, 0x45, 0xf5
2017-04-22 18:56:52.760 Detail, Node004, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2017-04-22 18:56:52.760 Detail, Node004, ZW_SEND_DATA delivered to Z-Wave stack
2017-04-22 18:56:52.783 Detail, Node004, Received: 0x01, 0x07, 0x00, 0x13, 0x45, 0x00, 0x00, 0x02, 0xac
2017-04-22 18:56:52.783 Detail, Node004, ZW_SEND_DATA Request with callback ID 0x45 received (expected 0x45)
2017-04-22 18:56:52.789 Info, Node004, Request RTT 36 Average Request RTT 33
2017-04-22 18:56:52.789 Detail, Expected callbackId was received
2017-04-22 18:56:52.789 Detail, Expected reply was received
2017-04-22 18:56:52.789 Detail, Message transaction complete
2017-04-22 18:56:52.789 Detail, Node004, Removing current message
2017-04-22 18:56:52.790 Info, Node004, Sending (Send) message (Callback ID=0x46, Expected Reply=0x04) - ConfigurationCmd_Get (Node=4): 0x01, 0x0a, 0x00, 0x13, 0x04, 0x03, 0x70, 0x05, 0x03, 0x25, 0x46, 0xf4
2017-04-22 18:56:52.798 Detail, Node004, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2017-04-22 18:56:52.798 Detail, Node004, ZW_SEND_DATA delivered to Z-Wave stack
2017-04-22 18:56:52.820 Detail, Node004, Received: 0x01, 0x07, 0x00, 0x13, 0x46, 0x00, 0x00, 0x03, 0xae
2017-04-22 18:56:52.820 Detail, Node004, ZW_SEND_DATA Request with callback ID 0x46 received (expected 0x46)
2017-04-22 18:56:52.820 Info, Node004, Request RTT 30 Average Request RTT 31
2017-04-22 18:56:52.820 Detail, Expected callbackId was received
2017-04-22 18:56:52.836 Detail, Node004, Received: 0x01, 0x0b, 0x00, 0x04, 0x00, 0x04, 0x05, 0x70, 0x06, 0x03, 0x01, 0x01, 0x84
2017-04-22 18:56:52.836 Info, Node004, Response RTT 46 Average Response RTT 45
2017-04-22 18:56:52.837 Detail, Node004, Refreshed Value: old value=1, new value=1, type=list
2017-04-22 18:56:52.837 Detail, Node004, Changes to this value are not verified
2017-04-22 18:56:52.837 Info, Node004, Received Configuration report: Parameter=3, Value=1
2017-04-22 18:56:52.837 Detail, Node004, Expected reply and command class was received
2017-04-22 18:56:52.837 Detail, Node004, Message transaction complete
2017-04-22 18:56:52.837 Detail, Node004, Removing current message
2017-04-22 18:56:52.837 Detail, Node004, Notification: ValueChanged
2017-04-22 18:56:52.838 Info, Notification: Value Changed Home 0xf31737f2 Node 4 Genre config Class CONFIGURATION Instance 1 Index 3 Type list
I am about to break the damn light off the PCB its driving me mad…
