Hi Guys,
I am fairly new to HomeAssistant, I have a small home lab going for my learning and media consumption in my house, and I have a bunch of Sonoff Mini’s around the house that is flashed with Tasmota’s and added to HomeAssistant.
I run automation that turns on all the lights in the house around sunset, this automation also needs to turn off all the lights it turned on after 15 minutes, leaving those that were either turned on manually or through HA already before the automation. e.g. If I am sitting in the living room it’s already getting dark i and I instruct HA to turn on the living room light but all other room lights are off, they turn on via the automation, After 15 minutes have passed I need all rooms except the living room to be turned off.
Is this possible? Below is the code of the automation I am talking about.
alias: Magrib Azan
- platform: time_pattern
seconds: '30'
condition:
- condition: template
value_template: '{{ now().time().strftime("%H:%M") == states.sensor.maghrib.state }}'
- if:
- condition: device
type: is_off
device_id: 9d4e5f4451761cc4c278a7f0c3fe1448
entity_id: switch.tasmota_2
domain: switch
then:
- type: turn_on
domain: switch
- if:
- condition: device
type: is_off
device_id: af1e76ca8e8c4c04b3e1d07d0e38ed23
entity_id: switch.bedroommainlight
domain: switch
then:
- type: turn_on
domain: switch
- if:
- condition: device
type: is_off
device_id: 22a3e66ebb96c9250708088b2d67aa0d
entity_id: switch.officemainlight
domain: switch
then:
- type: turn_on
domain: switch
- if:
- condition: device
type: is_off
device_id: 9d9c26c536e4a88ab54ed8d15dd67509
entity_id: switch.diningfan
domain: switch
then:
- type: turn_on
domain: switch
- service: media_player.volume_set
volume_level: 1
device_id:
- 9fb1f93ea3f38907af42a0c3348e07ec
- d6d44479977b1fb112a58b9ca4cb2767
volume_level: 0.5
device_id: fc104b57ce430460c5de60e1add722ba
- service: media_player.play_media
media_content_id: https://www.islamcan.com/audio/adhan/azan3.mp3
media_content_type: audio/mp3
entity_id:
- media_player.allhomespeakers
Also is the above the best method to run the automation and light control, or is there a better method to control the lights through the above automation, like creating a scene or something?
Thanks in advance for your help and suggestions.
