Turning sensors into lights for MQTT Hub
Hi there,
I set up a mosquito server in HA and a MQTT client in my main smart home system iobroker to get the data from there into HA. In the configuration.yaml I set up several MQTT sensors, which are transferring the data of the specific devices.
mqtt:
    - name: "ioBroker Hochlampe"
      state_topic: "iobroker/Hochlampe_Büro/Helligkeit"
      unique_id: "io_hochlampe_br"
Data transfer is working :white_check_mark:
Now, I also installed MatterHub to get the devices into my Google Home, but it seems as MatterHub doesn’t recognize sensors, despite temperature.
Is there a way to transfer the imported sensor, for example into a light which would be recognizable by MatterHub. For example via some kind of Alias or mirroring. I am aware that this isn’t a nice solution :neutral_face: or am I not using MatterHub correctly? Other devices which are directly integrated into HA are getting found by MatterHub
This one is found
of these 2 marked with the label iobroker, which is set on the include list of Matter Hub
Regards
maxpd
